Ciao,
I tried the latest version 2.201 but this was for me a disaster.
I’m using RP3 to run Volumio.
Once installed and started, noway to connect either through wired connection or WiFi connection.
I can see the RP3 on my network and even ping it but using volumio.local, no connection. Same if I use the IP address.
I also tried the hotspot. I’m able to connect my iPad on it, but nothing more.
If I connect the RP3 on a monitor, I can see that Volumio is started and access to the prompt.
I also tested by upgrading Volumio from the menu System. The upgrade seems to normally achieve but then, I get the same result : no connection at all and the Volumio app (or the web browser) doesn’t see it any more.
Re-inserting the sd card with version 2.129, all work fine and come to a normal behaviour.
Because I can access to the prompt, any command that I can enter to test or setup ?
Any clue are welcomed :mrgreen:
Pascal
