First, thanks for an awesome product, on the Pi with a DAC i finally have a audio streamer the family can easily and reliably use! Excellent.
I have one issue I cannot fix though regarding compilation albums.
I have the albums tagged with artist - song artist, album artist - Various. However when browsing Album view in volumio, what should appear as a single album is split into an album per track - very frustrating.
Does any one know how to ressolve this please?
My settings in my music are:
Compilation Metadata Fields: Various
Sort Artists By: albumartist
If all tracks on your compilation albums have the āalbumartistā field set to āVarious Artistsā it should work. This way each track can have its own āartistā, but the album is still recognised as one.
Even though all mu music had āalbum artistā tagged as āVariousā in tag&rename, when i opened the same files in mp3tag - āalbum artistā wasnt populated. I populated it in mp3tag, rescanned and all is good
None of the above (and what I found in other treads) worked for me. Almost drove me crazy.
But by chance i found that setting the tag PERFORMER to Various Artists (or the name of the main artist in collaboration albums) worked for me (Volumio 3.396) Now tese albums show as a single album in the album view.
So yeah⦠setting the Albumartist tag had no effect. Can anyone tell me why?
Still deciding if I should buy Volumio⦠I really like it but this costed me a few frustrating days to figure out and the documentation and forums didnāt help.
Check the compilation fields, and the sort option. The options in that screenshot are default for the current version of Volumio that I installed recently.
I had this issue as well. Looked at my files, and I didnāt have anything other than the artist tag set for each track, and since Volumio is relying on that rather than the directory name (like I used to).
Setting albumartist=Various for all tracks of compilation albums fixed this for me. I used āmetaflacā for this. You should probably use whatever tagging method youāre already using.
Note that Volumio still has to pickup the changes, so you have to go into Sources and click āUpdateā.
