V3.742 Rpi 4 Display resolution 1366 x 768
The artwork image is not resizing correctly - this problem has arisen before …
Michael
Michael
Adjust the zoom factor in the touch display plugin.
@Newbiggen’s screenshot shows Volumio in a browser on a Windows desktop. In that case adjusting the zoom factor on the Touch Display plugin’s config page will not help.
@gvolt
haha, missed that. At least someone is paying attention
@Newbiggen
Hold the CTRL button of your keyboard and turn the scrollwheel of your mouse.
Like yours:
After using the CTRL+Scroll:
I can use CTRL + mouse wheel to resize, but the adjustment is too crude - either the artwork is too small and the text is too large or, the artwork is too large and the text is too small.
I cannot get the sizing as it was before the update - not a satisfactory situation from my point of view
This problem has occured before with v 3.611 and was resolved in a subsequent update. It has appeared again in the latest update.
I attached 2 screenshots - The first is before the recent update
The second is after the update to v 3.742
Note how the progress bar now extends through the image.and the buttons are inconveniently positioned.
This problem needs attention please - changing the browser zoom settings does not resolve the issue.
Thanks in anticipation
Michael
Thank you for bringing this issue to our attention. We have noted the problem and added it to our to-do list for further investigation.
We appreciate your patience as we work to resolve this.
Best regards,
Volumio Support Team
Just keeping this topic ‘alive’ - I have just tried latest test version 3.754. The screenshot shows that there is still a problem with the progress bar and buttons not aligning correctl with the artwork. This problem was corrected in version 3.703 but re-appeared in 3.742. Hopefully it will be corrected before the next release.
Many thanks for the development work
Michael
