@michelangelo
What a condescending statement to write ;-
““Before being so disappointed. Did you even tried rebooting? For me it works perfectly.””
Of course I rebooted! ( In fact after setting up the system using the Volumio web GUI, Volumio reboots itself anyway!)
I am coming to the conclusion that you have a hybrid installation on your test rig, that does not reflect real world situations.
What do you mean for me it works perfectly? — expand please!
What happens if you take a fresh micro SD card and down load the advertised V1.5 from the DL URL ???
What kernel version do you get?
Does Volumio “see” the Pi-DAC Plus?
What is the kernel version of the distribution that you find is working?
Is that based on a Raspberry Pi B Plus AND a QI-Audio PI-DAC PLUS?
Re your comment:-
And report:
1- Is your i2s DAC working?
2- Are you on Raspberry PI B or B+?
3- Report which i2s DAC you use
4- Report which bitrates and bitdepths (16/24 ecc) works and which doesn’t
If I can collect enough data, you can expect a fix in 2 days (without reflashing). Whining, speculating, writing in capital letters, sarcasm and all this stuff doesn’t help.
I am annoyed, because I tried to get my syatem working with V1.41 , it failed miserably, and I appealed for help here and received no help from you at all!
I then see you posted V1.5 is available and the change notice states that RPI B+ and Pi-Dac plus is supported.
I then find it still doesn’t work, so you must realise that my expectation of a working product have been spoilt again.
I have already posted all the relevant information in my first and second posts above, please read and try to understand what I said.
But to make it absolutely clear:-
The Pi B plus and the Pi-dac plus work fine (except on Volumio)
After downloading Volumio version V1.5 from your web site, and running it, Volumio does not “find” the Pi-DAC Plus.
In fact, connecting to the Pi with SSH and running aplay -l only shows PI internal audio.
Uname -r on the down loaded Volumio V 1.5 shows kernel V 3.12.29+
Running rpi-update changes the kernel version to 3.12.31+ After which, Volumio “sees” the Pi-DAC plus. It runs on 44.1 Khz but works very badly on higher bit rates, Sounds like it is playing at three times proper speed.
So, I cannot understand how you can claim that Version V1.5 supports the RPI B+ and Pi-DAC plus and it is working on your setup!
regards
Patrick
