Hi All,
I am glad to introduce you to my little site.
vamp.obu4enie.kiev.ua
It is mainly on Russian
I am ready to cooperate with all and to share interesting information!
Second VAMP on Cubieboard A10
That’s a couple of good looking cases.
It could be me but i don’t get the “V.A.M.P.” part… might be because I don’t read/speak Russian.
And what is inside the first one?
cntvna.com/gp2015/2015-09/23 … icle.shtml
on 00:03:05 you can see volumio
here u can vote for this video!help my friend to win! 19 lines down
cntvna.com/gp2015/submissions.shtml
First on A20
http://www.facebook.com/VAMPdigitall/ :ugeek: :ugeek:
Unofficial firmware for cubieboard a10 based on version 1.5.*
[code]The software part:
ARMBian Linux platform optimized for the ARM.
- The kernel Linux Kernel 4.4;
- Sound system ALSA Library (alsa-lib) 1.1.0 / Plugins (alsa-plugins) 1.1.0;
- The latest version of the player Music Player Daemon (MPD) 0.19.12 + Patchlintweaker DSD_Native to support new devices;
- Custom modified version of the web interface Volumio.
[/code]
Current developments and optimizations for the latest version of the system software:
- Fixed a bug with the CUE file support (only works for one file);
- Added soft-off button;
- Disabled virtual disk in memory;
- Updated internal libraries for OS
- Added support for SMB protocol to access the internal storage;
- The maximum limit logging;
- Fixed a critical issue after the failure of the external SMB-balls by
add button delete entries in the table DB;
- Fixed a problem with the ability to save and delete playlists;
- Added ability to view the free space on your internal storage via the web-based interface;
- Creation of own github.com repository for automatic updates;
- Added service menu;
- Completely disable the onboard sound device;
- Completely eliminated the problem with the activation mode Consume_mode restart service after MPD;
- Added a button DAC Info to display the information on playing in the used DAC.
Current and future challenges to finalize the software:
- Testing device for mode DSD Native c DAC s that support Mode DSD256 / DSD512 (very high priority);
- To add a mmap = yes / no sound output;
- Optimization of the automation download updates in the event of a completely new kernel / firmware;
- Completion of the web interface to add new features ...
add translate !
http://digitall.in.ua - new domain!
digitall.in.ua/forum/topic/v-a-m … #postid-68
V.A.M.P. for PC (free download)
I managed to overcome the problem with the auto-mounting of disks!
An important condition - on discs with music there should not be more than two sections!
They are automatically mounted with the folder / mnt / USB / sd **
After updating the library “USB UPDATE LIBRARY - Only the database for internal SATA storage is updated” (we read the instruction on the link) the disks that have music are displayed in the list!
After updating online, a new REALTIME Linux kernel VAMP 4.16.12 will be installed. In this kernel, the number of supporting DSD_Native DACs is increased to Amanero! Also, a patch was used, which adds the entire list of DSD_Native heads.
