I upgraded a number of pi devices to v3.616. When I tried to upgrade the libraries (added new music to NAS) on all of them the library disappeared. I had to restart each device and then the upgrade started to rebuild the library
There are some problems with the current version and network drives. If it’s working now, hang on for a while as the issues will be fixed in the upcoming release.
please try to enable test mode and update to the latest version 3.629, and check if then your issue is solved
Hi Darmur, I installed 3.629. The library was still there when it restarted, and then updated correctly as I had just added new music to my NAS.
Excellent result!
Many thanks
Michael
