I just updated 2.041 to 2.118 (through the web UI) on my RPi 3, and now it seems volumio cannot connect to my wifi (which was working flawlessly before, and is still working for other devices). I have the hostpot disabled (I have tried with it enabled too), and this is the output from “sudo journalctl -f” when I try to enable wifi and save (minus some parts at the beginning and end, to stay withing the maximum post length):
Mar 12 14:11:12 volumio wireless.js[7008]: dhclientstderr: dhcpcd[7063]: sending commands to master dhcpcd process
Mar 12 14:11:12 volumio wpa_supplicant[7058]: Line 11: Invalid WEP key length 8 - this network block will be ignored
Mar 12 14:11:12 volumio wpa_supplicant[7058]: Priority group 1
Mar 12 14:11:12 volumio wpa_supplicant[7058]: id=0 ssid='TP-LINK_0CDBF2'
Mar 12 14:11:12 volumio wpa_supplicant[7058]: id=1 ssid='TP-LINK_0CDBF2'
Mar 12 14:11:12 volumio wpa_supplicant[7058]: rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: rfkill: initial event: idx=1 type=2 op=0 soft=0 hard=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Using driver-based roaming
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: TDLS supported
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported cipher 00-0f-ac:1
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported cipher 00-0f-ac:5
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported cipher 00-0f-ac:2
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported cipher 00-0f-ac:4
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported cipher 00-0f-ac:6
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Using driver-based off-channel TX
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Use separate P2P group interface (driver advertised support)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Enable multi-channel concurrent (driver advertised support)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: interface wlan0 in phy phy0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Set mode ifindex 3 iftype 2 (STATION)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Subscribe to mgmt frames with non-AP handle 0x5508b9f0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040a
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040b
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040c
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040d
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090a
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090b
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090c
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090d
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0409506f9a09
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=7f506f9a09
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0801
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040e
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=06
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0a07
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0a11
Mar 12 14:11:12 volumio wpa_supplicant[7058]: netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: driver param='(null)'
Mar 12 14:11:12 volumio wpa_supplicant[7058]: Add interface wlan0 to a new radio phy0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Regulatory information - country=00
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 2402-2472 @ 40 MHz 20 mBm
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: 57240-63720 @ 2160 MHz 0 mBm
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Added 802.11b mode based on 802.11g information
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Do not indicate P2P_DEVICE support (p2p_device=1 driver param not specified)
Mar 12 14:11:12 volumio kernel: brcmfmac: power management disabled
Mar 12 14:11:12 volumio kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
Mar 12 14:11:12 volumio wireless.js[7008]: dhclientchild process exited with code 0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wlan0: Own MAC address: b8:27:eb:ad:50:f2
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wlan0: RSN: flushing PMKID list in the driver
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Flush PMKIDs
Mar 12 14:11:12 volumio wpa_supplicant[7058]: TDLS: TDLS operation supported by driver
Mar 12 14:11:12 volumio wpa_supplicant[7058]: TDLS: Driver uses internal link setup
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wlan0: WPS: UUID based on MAC address: 0b93da8f-be70-542b-bf72-9d87cbd16ca2
Mar 12 14:11:12 volumio wpa_supplicant[7058]: EAPOL: SUPP_PAE entering state DISCONNECTED
Mar 12 14:11:12 volumio wpa_supplicant[7058]: EAPOL: Supplicant port status: Unauthorized
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Skip set_supp_port(unauthorized) while not associated
Mar 12 14:11:12 volumio wpa_supplicant[7058]: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
Mar 12 14:11:12 volumio wpa_supplicant[7058]: EAPOL: SUPP_BE entering state INITIALIZE
Mar 12 14:11:12 volumio wpa_supplicant[7058]: EAP: EAP entering state DISABLED
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: Add operating class 81
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: Own listen channel: 81:1
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: Random operating channel: 81:1
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: initialized
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
Mar 12 14:11:12 volumio wpa_supplicant[7058]: P2P: cli_channels:
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wlan0: Added interface wlan0
Mar 12 14:11:12 volumio wpa_supplicant[7058]: wlan0: State: DISCONNECTED -> DISCONNECTED
Mar 12 14:11:12 volumio wpa_supplicant[7058]: nl80211: Set wlan0 operstate 0->0 (DORMANT)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Mar 12 14:11:12 volumio wpa_supplicant[7058]: Daemonize..
Mar 12 14:11:12 volumio wpa_supplicant[7088]: random: Got 20/20 bytes from /dev/random
Mar 12 14:11:12 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=0 ifi_family=0 ifi_flags=0x1003 ([UP])
Mar 12 14:11:12 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
Mar 12 14:11:12 volumio wireless.js[7008]: wpa supplicantchild process exited with code 0
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Starting delayed sched scan
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Use normal scan instead of sched_scan for initial scans (normal_scans=0)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Setting scan request: 0.000000 sec
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: State: DISCONNECTED -> SCANNING
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Starting AP scan for wildcard SSID
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: Building WPS IE for Probe Request
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Version (hardcoded 0x10)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Request Type
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Config Methods (2148)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * UUID-E
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Primary Device Type
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * RF Bands (1)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Association State
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Configuration Error (0)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Device Password ID (0)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Manufacturer
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Model Name
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Model Number
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Device Name
Mar 12 14:11:12 volumio wpa_supplicant[7088]: WPS: * Version2 (0x20)
Mar 12 14:11:12 volumio wpa_supplicant[7088]: P2P: * P2P IE header
Mar 12 14:11:12 volumio wpa_supplicant[7088]: P2P: * Capability dev=25 group=00
Mar 12 14:11:12 volumio wpa_supplicant[7088]: P2P: * Listen Channel: Regulatory Class 81 Channel 1
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Add radio work 'scan'@0x5508c2a8
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: First radio work item in the queue - schedule start immediately
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Starting radio work 'scan'@0x5508c2a8 after 0.000612 second wait
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: nl80211: scan request
Mar 12 14:11:12 volumio wpa_supplicant[7088]: Scan requested (ret=0) - scan timeout 10 seconds
Mar 12 14:11:12 volumio wpa_supplicant[7088]: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: nl80211: Scan trigger
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Event SCAN_STARTED (49) received
Mar 12 14:11:12 volumio wpa_supplicant[7088]: wlan0: Own scan request started a scan in 0.000111 seconds
Mar 12 14:11:13 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP])
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: nl80211: New scan results available
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Scan probed for SSID 'TP-LINK_0CDBF2'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Scan probed for SSID ''
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Event SCAN_RESULTS (3) received
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Scan completed in 0.483612 seconds
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Received scan results (9 BSSes)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Start scan result update 1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 0 BSSID e8:94:f6:0c:db:f2 SSID 'TP-LINK_0CDBF2'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 1 BSSID dc:53:7c:76:96:db SSID 'Kalle'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 2 BSSID 30:91:8f:d1:c3:f1 SSID 'TN_24GHz_D1C3F1'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 3 BSSID 12:7b:ef:b9:0d:cc SSID 'TN_private_RPV9CE'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 4 BSSID 40:4a:03:f9:ef:78 SSID 'TN_private_H34F7K'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 5 BSSID 34:e0:cf:c1:79:6a SSID '3Bredband_C1796A'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 6 BSSID e0:b9:e5:61:e0:23 SSID 'Telia-61E023'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 7 BSSID c4:ea:1d:f3:64:8b SSID 'TN_24GHz_F3648B'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: BSS: Add new id 8 BSSID fa:8f:ca:7e:30:27 SSID ''
Mar 12 14:11:13 volumio wpa_supplicant[7088]: BSS: last_scan_res_used=9/32
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: New scan results available (own=1 ext=0)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP e8:94:f6:0c:db:f2 type 0 added
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP dc:53:7c:76:96:db type 0 added
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP 30:91:8f:d1:c3:f1 type 0 added
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP e0:b9:e5:61:e0:23 type 0 added
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP c4:ea:1d:f3:64:8b type 0 added
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP[0] e8:94:f6:0c:db:f2 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP[1] dc:53:7c:76:96:db type=0 tries=0 last_attempt=-1 sec ago blacklist=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP[2] 30:91:8f:d1:c3:f1 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP[3] e0:b9:e5:61:e0:23 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPS: AP[4] c4:ea:1d:f3:64:8b type=0 tries=0 last_attempt=-1 sec ago blacklist=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Radio work 'scan'@0x5508c2a8 done in 0.536390 seconds
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Selecting BSS from priority group 1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: 0: e8:94:f6:0c:db:f2 ssid='TP-LINK_0CDBF2' wpa_ie_len=0 rsn_ie_len=20 caps=0x431 level=-33 wps
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: selected based on RSN IE
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: selected BSS e8:94:f6:0c:db:f2 ssid='TP-LINK_0CDBF2'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Considering connect request: reassociate: 0 selected: e8:94:f6:0c:db:f2 bssid: 00:00:00:00:00:00 pending: 00:00:00:00:00:00 wpa_state: SCANNING ssid=0x5508b480 current_ssid=(nil)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Request association with e8:94:f6:0c:db:f2
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=16): 00 0e 54 50 2d 4c 49 4e 4b 5f 30 43 44 42 46 32
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=3): 03 01 0b
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=8): 07 06 53 45 20 01 0d 14
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=3): 2a 01 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: RSN IE in EAPOL-Key - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=28): 33 1a ef 11 1b ff ff 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=24): 3d 16 0b 07 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=24): 34 16 0b 07 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: WMM Parameter Element - hexdump(len=24): 00 50 f2 02 01 01 87 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: TDLS: TDLS is allowed in the target BSS
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Add radio work 'connect'@0x550a0168
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: First radio work item in the queue - schedule start immediately
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Starting radio work 'connect'@0x550a0168 after 0.000646 second wait
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Trying to associate with SSID 'TP-LINK_0CDBF2'
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Cancelling scan request
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: clearing own WPA/RSN IE
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Automatic auth_alg selection: 0x1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: RSN: PMKSA cache search - network_ctx=0x5508b480 try_opportunistic=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: RSN: Search for BSSID e8:94:f6:0c:db:f2
Mar 12 14:11:13 volumio wpa_supplicant[7088]: RSN: No PMKSA cache entry found
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: RSN: using IEEE 802.11i/D9.0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: Selected cipher suites: group 16 pairwise 16 key_mgmt 2 proto 2
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: Selected mgmt group cipher 32
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: clearing AP WPA IE
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: set AP RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: using GTK CCMP
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: using PTK CCMP
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: using KEY_MGMT WPA-PSK
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: WPA: not using MGMT group cipher
Mar 12 14:11:13 volumio wpa_supplicant[7088]: WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: State: SCANNING -> ASSOCIATING
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Set wlan0 operstate 0->0 (DORMANT)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_disable_max_amsdu: -1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_ampdu_factor: -1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_ampdu_density: -1
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_disable_ht40: 0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_disable_sgi: 0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: set_disable_ldpc: 0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Set mode ifindex 3 iftype 2 (STATION)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Unsubscribe mgmt frames handle 0xdd803179 (mode change)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Subscribe to mgmt frames with non-AP handle 0x5508b9f0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040a
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040b
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040c
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040d
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090a
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090b
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090c
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=090d
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0409506f9a09
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=7f506f9a09
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0801
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=040e
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=06
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0a07
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5508b9f0 match=0a11
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Connect (ifindex=3)
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * bssid_hint=e8:94:f6:0c:db:f2
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * freq_hint=2462
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * IEs - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * WPA Versions 0x2
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * pairwise=0xfac04
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * group=0xfac04
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * akm=0xfac02
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * htcaps - hexdump(len=26): 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * htcaps_mask - hexdump(len=26): 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * vhtcaps - hexdump(len=12): 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * vhtcaps_mask - hexdump(len=12): 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:13 volumio wpa_supplicant[7088]: * Auth Type 0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: nl80211: Connect request send successfully
Mar 12 14:11:13 volumio wpa_supplicant[7088]: wlan0: Setting authentication timeout: 10 sec 0 usec
Mar 12 14:11:13 volumio wpa_supplicant[7088]: EAPOL: External notification - EAP success=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: EAPOL: External notification - EAP fail=0
Mar 12 14:11:13 volumio wpa_supplicant[7088]: EAPOL: External notification - portControl=Auto
Mar 12 14:11:13 volumio wireless.js[7008]: trying...
Mar 12 14:11:13 volumio sudo[7090]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:13 volumio sudo[7090]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:13 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:13 volumio wpa_supplicant[7088]: EAPOL: disable timer tick
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: RX EAPOL from e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Not associated - Delay processing of received EAPOL frame (state=ASSOCIATING bssid=00:00:00:00:00:00)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Drv Event 46 (NL80211_CMD_CONNECT) received for wlan0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Connect event
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Associated on 2462 MHz
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Associated with e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Operating frequency for the associated BSS from scan results: 2462 MHz
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Event ASSOC (0) received
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Association info event
Mar 12 14:11:14 volumio wpa_supplicant[7088]: req_ies - hexdump(len=105): 00 0e 54 50 2d 4c 49 4e 4b 5f 30 43 44 42 46 32 01 08 82 84 8b 96 24 30 48 6c 32 04 0c 12 18 60 21 02 05 17 24 02 01 0d 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 2d 1a 21 00 1f ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 dd 09 00 10 18 02 00 10 00 00 00 0b 10 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: resp_ies - hexdump(len=126): 01 08 82 84 8b 0c 12 96 18 24 32 04 30 48 60 6c 2d 1a af 01 1b ff ff 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 33 1a af 01 1b ff ff 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 3d 16 0b 07 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34 16 0b 07 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 de ff a5 01
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=28): 33 1a af 01 1b ff ff 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=24): 3d 16 0b 07 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Unrecognized EAPOL-Key Key Data IE - hexdump(len=24): 34 16 0b 07 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: EAPOL-Key Key Data underflow (ie=222 len=255 pos=122)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Key Data - hexdump(len=126): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: IEEE 802.11 element parse failed (id=222 elen=255 left=2)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: freq=2462 MHz
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: set own WPA/RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: Truncated IE in assoc_info - hexdump(len=4): de ff a5 01
Mar 12 14:11:14 volumio wpa_supplicant[7088]: FT: Stored MDIE and FTIE from (Re)Association Response - hexdump(len=0):
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: State: ASSOCIATING -> ASSOCIATED
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Set wlan0 operstate 0->0 (DORMANT)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Associated to a new BSS: BSSID=e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: clearing AP WPA IE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: set AP RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Associated with e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Association event - clear replay counter
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Clear old PTK
Mar 12 14:11:14 volumio wpa_supplicant[7088]: TDLS: Remove peers on association
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - portEnabled=0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - portValid=0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - EAP success=0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - portEnabled=1
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: SUPP_PAE entering state CONNECTING
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: enable timer tick
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: SUPP_BE entering state IDLE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Setting authentication timeout: 10 sec 0 usec
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Cancelling scan request
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Process pending EAPOL frame that was received just before association notification
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: IEEE 802.1X RX: version=2 type=3 length=95
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: EAPOL-Key type=2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: key_info 0x8a (ver=2 keyidx=0 rsvd=0 Pairwise Ack)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: key_length=16 key_data_length=0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_nonce - hexdump(len=32): 2f 87 49 2d a2 ed 69 a3 96 e4 de 38 31 20 04 c7 fb 09 9a e5 45 b2 d8 7e 31 f2 ec ca a5 03 57 24
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: State: ASSOCIATED -> 4WAY_HANDSHAKE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: RX message 1 of 4-Way Handshake from e8:94:f6:0c:db:f2 (ver=2)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RSN: msg 1/4 key data - hexdump(len=0):
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Renewed SNonce - hexdump(len=32): 6c b8 eb 76 4f 55 da d6 70 e8 5a c1 d9 7b 4e e2 b3 6f be f7 e0 f7 63 76 1a 5a 93 07 6a 57 71 ab
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: PTK derivation - A1=b8:27:eb:ad:50:f2 A2=e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Nonce1 - hexdump(len=32): 6c b8 eb 76 4f 55 da d6 70 e8 5a c1 d9 7b 4e e2 b3 6f be f7 e0 f7 63 76 1a 5a 93 07 6a 57 71 ab
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Nonce2 - hexdump(len=32): 2f 87 49 2d a2 ed 69 a3 96 e4 de 38 31 20 04 c7 fb 09 9a e5 45 b2 d8 7e 31 f2 ec ca a5 03 57 24
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: PMK - hexdump(len=32): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: PTK - hexdump(len=48): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: WPA IE for msg 2/4 - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 01
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Sending EAPOL-Key 2/4
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: KCK - hexdump(len=16): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Derived Key MIC - hexdump(len=16): 48 29 32 25 bc ab b5 45 91 c2 90 86 b5 9f d1 c3
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlan0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Regulatory domain change
Mar 12 14:11:14 volumio wpa_supplicant[7088]: * initiator=3
Mar 12 14:11:14 volumio wpa_supplicant[7088]: * type=0
Mar 12 14:11:14 volumio wpa_supplicant[7088]: * alpha2=SE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Event CHANNEL_LIST_CHANGED (30) received
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=SE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Regulatory information - country=SE (DFS-ETSI)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: 2402-2482 @ 40 MHz 20 mBm
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: 5170-5250 @ 80 MHz 20 mBm
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: 5490-5710 @ 160 MHz 27 mBm (DFS)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: 57000-66000 @ 2160 MHz 40 mBm
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Added 802.11b mode based on 802.11g information
Mar 12 14:11:14 volumio wpa_supplicant[7088]: P2P: Add operating class 81
Mar 12 14:11:14 volumio wpa_supplicant[7088]: P2P: Channels - hexdump(len=13): 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d
Mar 12 14:11:14 volumio wpa_supplicant[7088]: P2P: Update channel list
Mar 12 14:11:14 volumio wpa_supplicant[7088]: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11,12,13
Mar 12 14:11:14 volumio wpa_supplicant[7088]: P2P: cli_channels:
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: IEEE 802.1X RX: version=2 type=3 length=151
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: key_info 0x13ca (ver=2 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: key_length=16 key_data_length=56
Mar 12 14:11:14 volumio wpa_supplicant[7088]: replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_rsc - hexdump(len=8): 82 00 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: key_mic - hexdump(len=16): db 28 b7 a5 cd 0b 63 bd 4c f0 48 2d 96 41 34 7a
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RSN: encrypted key data - hexdump(len=56): 28 ae 49 3a 78 6a b8 77 a6 b0 25 16 d0 a2 7e 72 a6 77 0d 8d dd d0 d3 6b 3d 5e f7 b7 a0 b4 48 99 8a ee d5 ad 63 04 69 02 4d 1f d6 6b e9 bd 30 c5 32 4c 5f 32 dd 92 f9 92
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: decrypted EAPOL-Key key data - hexdump(len=48): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: RX message 3 of 4-Way Handshake from e8:94:f6:0c:db:f2 (ver=2)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: IE KeyData - hexdump(len=48): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 dd 16 00 0f ac 01 01 00 8d a4 11 75 70 24 e9 ff e1 85 48 4b 89 fb 41 2f dd 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: RSN IE in EAPOL-Key - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: GTK in EAPOL-Key - hexdump(len=24): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Sending EAPOL-Key 4/4
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Derived Key MIC - hexdump(len=16): 79 70 8d 86 e2 f2 00 32 e0 47 80 98 c8 3e c9 37
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Installing PTK to the driver
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=3 addr=0x5508bfc0 key_idx=0 set_tx=1 seq_len=6 key_len=16
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: KEY_DATA - hexdump(len=16): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: KEY_SEQ - hexdump(len=6): 00 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: addr=e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - portValid=1
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: State: 4WAY_HANDSHAKE -> GROUP_HANDSHAKE
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RSN: received GTK in pairwise handshake - hexdump(len=18): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: Group Key - hexdump(len=16): [REMOVED]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Installing GTK to the driver (keyidx=1 tx=0 len=16)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: WPA: RSC - hexdump(len=6): 82 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=3 addr=0x54ca5f4c key_idx=1 set_tx=0 seq_len=6 key_len=16
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: KEY_SEQ - hexdump(len=6): 82 00 00 00 00 00
Mar 12 14:11:14 volumio wpa_supplicant[7088]: broadcast key
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: WPA: Key negotiation completed with e8:94:f6:0c:db:f2 [PTK=CCMP GTK=CCMP]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Cancelling authentication timeout
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: State: GROUP_HANDSHAKE -> COMPLETED
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: Radio work 'connect'@0x550a0168 done in 0.839206 seconds
Mar 12 14:11:14 volumio wpa_supplicant[7088]: wlan0: CTRL-EVENT-CONNECTED - Connection to e8:94:f6:0c:db:f2 completed [id=0 id_str=]
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Set wlan0 operstate 0->1 (UP)
Mar 12 14:11:14 volumio wpa_supplicant[7088]: netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
Mar 12 14:11:14 volumio dhcpcd[520]: wlan0: carrier acquired
Mar 12 14:11:14 volumio dhcpcd[520]: wlan0: adding address fe80::ba27:ebff:fead:50f2
Mar 12 14:11:14 volumio dhcpcd[520]: if_addaddress6: Permission denied
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: External notification - EAP success=1
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: SUPP_PAE entering state AUTHENTICATING
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: SUPP_BE entering state SUCCESS
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAP: EAP entering state DISABLED
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: SUPP_PAE entering state AUTHENTICATED
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL: Supplicant port status: Authorized
Mar 12 14:11:14 volumio wpa_supplicant[7088]: nl80211: Set supplicant port authorized for e8:94:f6:0c:db:f2
Mar 12 14:11:14 volumio dhcpcd[520]: wlan0: IAID eb:ad:50:f2
Mar 12 14:11:14 volumio wpa_supplicant[7088]: EAPOL authentication completed - result=SUCCESS
Mar 12 14:11:14 volumio wpa_supplicant[7088]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=6 linkmode=1 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Mar 12 14:11:14 volumio kernel: cfg80211: Regulatory domain changed to country: SE
Mar 12 14:11:14 volumio kernel: cfg80211: DFS Master region: ETSI
Mar 12 14:11:14 volumio kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Mar 12 14:11:14 volumio kernel: cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Mar 12 14:11:14 volumio kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Mar 12 14:11:14 volumio kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Mar 12 14:11:14 volumio kernel: cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
Mar 12 14:11:14 volumio kernel: cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Mar 12 14:11:14 volumio wireless.js[7008]: trying...
Mar 12 14:11:14 volumio sudo[7098]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:14 volumio sudo[7098]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:14 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:14 volumio dhcpcd[520]: wlan0: rebinding lease of 192.168.10.211
Mar 12 14:11:14 volumio dhcpcd[520]: wlan0: soliciting an IPv6 router
Mar 12 14:11:15 volumio wireless.js[7008]: trying...
Mar 12 14:11:15 volumio sudo[7103]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:15 volumio sudo[7103]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:15 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:15 volumio ntpd[897]: Deleting interface #15 eth0, 192.168.10.136#123, interface stats: received=71, sent=72, dropped=0, active_time=1032 secs
Mar 12 14:11:15 volumio ntpd[897]: 194.71.144.71 interface 192.168.10.136 -> (none)
Mar 12 14:11:15 volumio ntpd[897]: 193.228.143.24 interface 192.168.10.136 -> (none)
Mar 12 14:11:15 volumio ntpd[897]: 193.228.143.14 interface 192.168.10.136 -> (none)
Mar 12 14:11:15 volumio ntpd[897]: 192.36.143.130 interface 192.168.10.136 -> (none)
Mar 12 14:11:15 volumio ntpd[897]: peers refreshed
Mar 12 14:11:16 volumio wpa_supplicant[7088]: EAPOL: startWhen --> 0
Mar 12 14:11:16 volumio wpa_supplicant[7088]: EAPOL: disable timer tick
Mar 12 14:11:16 volumio dhcpcd[1003]: eth0: probing for an IPv4LL address
Mar 12 14:11:16 volumio wireless.js[7008]: trying...
Mar 12 14:11:16 volumio dhcpcd[1003]: eth0: DHCP lease expired
Mar 12 14:11:16 volumio sudo[7108]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:16 volumio sudo[7108]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:16 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:16 volumio dhcpcd[1003]: eth0: soliciting a DHCP lease
Mar 12 14:11:16 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.22.74
Mar 12 14:11:16 volumio dhcpcd[1003]: eth0: offered 192.168.10.136 from 192.168.10.1
Mar 12 14:11:17 volumio wireless.js[7008]: trying...
Mar 12 14:11:17 volumio sudo[7122]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:17 volumio sudo[7122]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:17 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:17 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.138.44
Mar 12 14:11:18 volumio wireless.js[7008]: trying...
Mar 12 14:11:18 volumio sudo[7127]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:18 volumio sudo[7127]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:18 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:18 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.117.166
Mar 12 14:11:19 volumio dhcpcd[520]: wlan0: leased 192.168.10.211 for 43200 seconds
Mar 12 14:11:19 volumio avahi-daemon[1393]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.10.211.
Mar 12 14:11:19 volumio avahi-daemon[1393]: New relevant interface wlan0.IPv4 for mDNS.
Mar 12 14:11:19 volumio dhcpcd[520]: wlan0: adding route to 192.168.10.0/24
Mar 12 14:11:19 volumio dhcpcd[520]: wlan0: adding default route via 192.168.10.1
Mar 12 14:11:19 volumio avahi-daemon[1393]: Registering new address record for 192.168.10.211 on wlan0.IPv4.
Mar 12 14:11:19 volumio wireless.js[7008]: trying...
Mar 12 14:11:19 volumio sudo[7156]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:19 volumio sudo[7156]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:19 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:19 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.87.254
Mar 12 14:11:20 volumio dhcpcd[520]: eth0: leased 192.168.10.136 for 43200 seconds
Mar 12 14:11:20 volumio dhcpcd[520]: eth0: adding route to 192.168.10.0/24
Mar 12 14:11:20 volumio avahi-daemon[1393]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.10.136.
Mar 12 14:11:20 volumio avahi-daemon[1393]: New relevant interface eth0.IPv4 for mDNS.
Mar 12 14:11:20 volumio dhcpcd[520]: eth0: adding default route via 192.168.10.1
Mar 12 14:11:20 volumio avahi-daemon[1393]: Registering new address record for 192.168.10.136 on eth0.IPv4.
Mar 12 14:11:20 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 192.168.10.136
Mar 12 14:11:20 volumio volumio[1324]: Discovery: adding 4b76747a-7e19-49fe-8de7-0d4caa1d69c2
Mar 12 14:11:20 volumio volumio[1324]: info: mDNS: Found device Volumio
Mar 12 14:11:20 volumio volumio[1324]: Discovery: this is already registered, 4b76747a-7e19-49fe-8de7-0d4caa1d69c2
Mar 12 14:11:20 volumio wireless.js[7008]: trying...
Mar 12 14:11:20 volumio sudo[7187]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:20 volumio sudo[7187]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:20 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.167.77
Mar 12 14:11:20 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:21 volumio dhcpcd[1003]: eth0: soliciting a DHCP lease
Mar 12 14:11:21 volumio volumio[1324]: info: CoreCommandRouter::executeOnPlugin: upnp , onRestart
Mar 12 14:11:21 volumio sudo[7192]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall upmpdcli
Mar 12 14:11:21 volumio sudo[7192]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 12 14:11:21 volumio volumio[6754]: :2:src/ohmetacache.cxx:122::dmcacheSaveWorker: can't get task from queue
Mar 12 14:11:21 volumio volumio[6754]: :3:/usr/include/libupnpp/workqueue.h:193::SaveQueue: tasks 0 nowakes 0 wsleeps 1 csleeps 0
Mar 12 14:11:21 volumio mpd[570]: client: [11] closed
Mar 12 14:11:21 volumio sudo[7192]: pam_unix(sudo:session): session closed for user root
Mar 12 14:11:21 volumio sudo[7205]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start upmpdcli.service
Mar 12 14:11:21 volumio sudo[7205]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 12 14:11:21 volumio systemd[1]: Starting UPnP Renderer front-end to MPD...
Mar 12 14:11:21 volumio systemd[1]: Started UPnP Renderer front-end to MPD.
Mar 12 14:11:21 volumio sudo[7205]: pam_unix(sudo:session): session closed for user root
Mar 12 14:11:21 volumio volumio[1324]: info: Upmpdcli Daemon Started
Mar 12 14:11:21 volumio mpd[570]: client: [12] opened from ::ffff:127.0.0.1:41116
Mar 12 14:11:21 volumio ntpd[897]: Listen normally on 24 eth0 192.168.10.136 UDP 123
Mar 12 14:11:21 volumio ntpd[897]: Listen normally on 25 wlan0 192.168.10.211 UDP 123
Mar 12 14:11:21 volumio ntpd[897]: peers refreshed
Mar 12 14:11:21 volumio dhcpcd[1003]: eth0: hardware address b8:27:eb:ad:50:f2 claims 169.254.54.130
Mar 12 14:11:21 volumio wireless.js[7008]: trying...
Mar 12 14:11:21 volumio sudo[7225]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:21 volumio sudo[7225]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:21 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:22 volumio dhcpcd[1003]: eth0: leased 192.168.10.136 for 43200 seconds
Mar 12 14:11:22 volumio dhcpcd[520]: eth0: removing route to 192.168.10.0/24
Mar 12 14:11:22 volumio dhcpcd[1003]: eth0: adding route to 192.168.10.0/24
Mar 12 14:11:22 volumio dhcpcd[1003]: eth0: adding default route via 192.168.10.1
Mar 12 14:11:22 volumio dhcpcd[520]: eth0: removing default route via 192.168.10.1
Mar 12 14:11:22 volumio dhcpcd[1003]: eth0: removing route to 192.168.10.0/24
Mar 12 14:11:22 volumio dhcpcd[1003]: eth0: removing default route via 192.168.10.1
Mar 12 14:11:22 volumio wireless.js[7008]: trying...
Mar 12 14:11:22 volumio sudo[7250]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:22 volumio sudo[7250]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:22 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:23 volumio wireless.js[7008]: trying...
Mar 12 14:11:23 volumio sudo[7256]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:23 volumio sudo[7256]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:23 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:24 volumio wireless.js[7008]: trying...
Mar 12 14:11:24 volumio sudo[7261]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:24 volumio sudo[7261]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:24 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:25 volumio wireless.js[7008]: trying...
Mar 12 14:11:26 volumio sudo[7266]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:26 volumio sudo[7266]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:26 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:27 volumio wireless.js[7008]: trying...
Mar 12 14:11:27 volumio sudo[7272]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:27 volumio sudo[7272]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:27 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:28 volumio wireless.js[7008]: trying...
Mar 12 14:11:28 volumio sudo[7277]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:28 volumio sudo[7277]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:28 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:29 volumio wireless.js[7008]: trying...
Mar 12 14:11:29 volumio sudo[7282]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:29 volumio sudo[7282]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:29 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:30 volumio wireless.js[7008]: trying...
Mar 12 14:11:30 volumio sudo[7287]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:30 volumio sudo[7287]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:30 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:31 volumio wireless.js[7008]: trying...
Mar 12 14:11:31 volumio sudo[7292]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:31 volumio sudo[7292]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:31 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:32 volumio wireless.js[7008]: trying...
Mar 12 14:11:32 volumio sudo[7297]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:32 volumio sudo[7297]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:32 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:33 volumio wireless.js[7008]: trying...
Mar 12 14:11:33 volumio sudo[7302]: pam_unix(sudo:auth): conversation failed
Mar 12 14:11:33 volumio sudo[7302]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Mar 12 14:11:33 volumio wireless.js[7008]: sudo: no tty present and no askpass program specified
Mar 12 14:11:34 volumio wireless.js[7008]: Overtime, starting plan B
Mar 12 14:11:34 volumio wireless.js[7008]: killing: kill `pgrep -f "^/usr/bin/sudo"` || true
Mar 12 14:11:34 volumio wireless.js[7008]: killing: kill `pgrep -f "^wpa_supplicant"` || true
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Removing interface wlan0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Request to deauthenticate - bssid=e8:94:f6:0c:db:f2 pending_bssid=00:00:00:00:00:00 reason=3 state=COMPLETED
Mar 12 14:11:34 volumio wpa_supplicant[7088]: TDLS: Tear down peers
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wpa_driver_nl80211_disconnect(reason_code=3)
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Event DEAUTH (12) received
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Deauthentication notification
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: * reason 3 (locally generated)
Mar 12 14:11:34 volumio wpa_supplicant[7088]: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: CTRL-EVENT-DISCONNECTED bssid=e8:94:f6:0c:db:f2 reason=3 locally_generated=1
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Auto connect disabled: do not try to re-connect
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Ignore connection failure indication since interface has been put into disconnected state
Mar 12 14:11:34 volumio wpa_supplicant[7088]: TDLS: Remove peers on disassociation
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: Disconnect event - remove keys
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=0x5508aa48 key_idx=0 set_tx=0 seq_len=0 key_len=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: addr=e8:94:f6:0c:db:f2
Mar 12 14:11:34 volumio dhcpcd[520]: wlan0: carrier lost
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: State: COMPLETED -> DISCONNECTED
Mar 12 14:11:34 volumio wpa_supplicant[7088]: nl80211: Set wlan0 operstate 1->0 (DORMANT)
Mar 12 14:11:34 volumio wpa_supplicant[7088]: netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: External notification - portEnabled=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: SUPP_PAE entering state DISCONNECTED
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: Supplicant port status: Unauthorized
Mar 12 14:11:34 volumio wpa_supplicant[7088]: nl80211: Skip set_supp_port(unauthorized) while not associated
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: SUPP_BE entering state INITIALIZE
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: External notification - portValid=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: EAPOL: External notification - EAP success=0
Mar 12 14:11:34 volumio wpa_supplicant[7088]: wlan0: State: DISCONNECTED -> DISCONNECTED
Mar 12 14:11:34 volumio wpa_supplicant[7088]: nl80211: Set wlan0 operstate 0->0 (DORMANT)
I wonder if these lines, repeated many times, are relevant:
