While working on upgrading from 1.4, it proved easier to switch from between versions if the content of /etc/ were provided by symlinking from /etc/ to the target directory.
For example, the content of Volumio is normally housed under /var/www/:
- I pulled the git content into /home/earl/volumio/.
- For each file in /etc/ that is shadowed in volumio/_OS_SETTINGS/, create a symlink in /etc/ to that file. See the list below.
- Create a symlink from /home/volumio to volumio/_OS_SETTINGS/home/volumio/.
- Create a symlink from /var/www/ to /home/earl/volumio/.
- Leave /boot/cmdline.txt unlinked because it crosses a file system.
Some benefits of doing this:
- For the most part, versions can be switched (eg git checkout) without having to copy files to /etc/.
- Versions can be deployed side-by-side and compared easily. For example I left 1.4 installed in /var/www-1.4 and switched between the different versions by adjusting /var/www to point to either www-1.4 or /home/earl/volumio/.
I think there is one other significant benefit, and that is to make updating more robust. For example, here is one possibility:
- Download the update into /var/www-1.5/ (or whatever the new version is).
- Deploy new symlinks into /etc/ pointing them into /var/www/.
- Change the symlink from /var/www to point to www-1.5: ln -sfn www-1.5 /var/www
The key idea here is that the switch to the new version is done as an atomic operation in the final step ©, and that preparation for that final step is done as a sequence of restartable steps beforehand.
The remain some issues:
- Totally new files in /etc/. Perform step (b) and those symlinks will point at non-existent files in /var/www-1.4 (or whatever the previous version is).
- Replacing existing files in /etc/. This is trickier. I think the best approach would be to have a pre-upgrade step that copies /var/www/ into /var/www-tmp/. Copy the files in /etc/ that will be replaced into /var/www-tmp/. Create symlink (atomically) /var/www to point to www-tmp. Then for each replacement, create a corresponding symlink in /etc/ to /var/www. At this point the symlinks are in place, but they point at pre-existing content. Once the pre-upgrade step is complete, perform the upgrade steps (a) to ©.
- Removing content in /etc/. After performing upgrade steps (a) to ©, these symlinks in /etc/ will not be resolvable in /var/www-1.5 because this content no longer exists. As a post-upgrade step, remove the corresponding symlinks in /etc/ which point to content in /var/www which no longer exists.
etc/fstab_raspberry -> ../var/www/_OS_SETTINGS/etc/fstab_raspberry
etc/init.d/boot.localfs-tmp -> ../../var/www/_OS_SETTINGS/etc/init.d/boot.localfs-tmp
etc/init.d/transientlog -> ../../var/www/_OS_SETTINGS/etc/init.d/transientlog
etc/init.d/upmpdcli -> ../../var/www/_OS_SETTINGS/etc/init.d/upmpdcli
etc/minidlna.conf -> ../var/www/_OS_SETTINGS/etc/minidlna.conf
etc/motd -> ../var/www/_OS_SETTINGS/etc/motd
etc/nginx/nginx.conf -> ../../var/www/_OS_SETTINGS/etc/nginx/nginx.conf
etc/php5/cli/php.ini -> ../../../var/www/_OS_SETTINGS/etc/php5/cli/php.ini
etc/php5/fpm/php-fpm.conf -> ../../../var/www/_OS_SETTINGS/etc/php5/fpm/php-fpm.conf
etc/php5/fpm/php.ini -> ../../../var/www/_OS_SETTINGS/etc/php5/fpm/php.ini
etc/php5/fpm/pool.d/command.conf -> ../../../../var/www/_OS_SETTINGS/etc/php5/fpm/pool.d/command.conf
etc/php5/fpm/pool.d/db.conf -> ../../../../var/www/_OS_SETTINGS/etc/php5/fpm/pool.d/db.conf
etc/php5/fpm/pool.d/display.conf -> ../../../../var/www/_OS_SETTINGS/etc/php5/fpm/pool.d/display.conf
etc/php5/mods-available/apc.ini -> ../../../var/www/_OS_SETTINGS/etc/php5/mods-available/apc.ini
etc/rc.local -> ../var/www/_OS_SETTINGS/etc/rc.local
etc/samba/smb.conf -> ../../var/www/_OS_SETTINGS/etc/samba/smb.conf
etc/upmpdcli.conf -> ../var/www/_OS_SETTINGS/etc/upmpdcli.conf
etc/usbmount -> ../var/www/_OS_SETTINGS/etc/usbmount
