One of my volumio systems is a portable device that uses a 64 GB SD card with a separate partition for music files. Previously with Volumio 2, I have removed the symbolic link for /mnt/USB and replaced it with a directory /mnt/USB, and mounted the music partition to this directory in /etc/fstab. This has worked fine and is recognised by Volumio 2. With the update to 0.976, something has changed, and Volumio no longer recognises the directory (music content is all there if I manually check by ssh).
Anyone know a solution to this one please; I don’t know enough about how Volumio works in regard to the filesystem.
