Hi.
Has anyone had experience using the Pimoroni on/off shim?
Any idea which GPIO pins it uses/occupies?
Hi.
We’ve put together a one-line-installer to install the clean shutdown daemon. It watches the state of BCM pin 17 and, when pulled low (pressed), it initiates a clean shutdown. Last thing, just before your Pi shuts down, BCM pin 4 is pulled low to completely cut power to your Pi.
To install the software, open a terminal and type curl https://get.pimoroni.com/onoffshim | bash
to run the one-line-installer.
Thanks for the info.
Does the Shim/software use GPIO 3 to wake up Pi? You do not make that clear in your info.
i don’t have it, i only searched for you the info … it should power on and off.
best regards,
dvo
OK many thanks.
I am waiting for further info. from Pimoroni so I will see then hopefully.
Looks like GPIO 4 and 17 (pins 7 & 11)
Thanks for the info. I will go ahead and order one.
