Hello!
I have poor WiFi reception. I am currently using Volumio with Raspi 3B. I would like to use an external adapter with an antenna for the improved WiFi connection.
Is that possible with Volumio?
Simply plugging it in doesn’t work for me.
The adapter is TP Link TL-WN822N
Thank you for your answers. The number of supported WiFi USB adapters has become extremely short.
Volumio uses Raspbian OS as its base - so I have understood the reason for the lack of support for USB WiFi dongles.
Cause of problem understood. I have to look for the solution outside the Volumio universe.
Your proposed solution is technically feasible. Even with other repeaters.
I prefer to be able to use the existing USB WiFi adapter.
To be able to use the TP Link TL-WN822N under Raspbian OS, I will have to invest time. Success is possible, but not guaranteed.
It is a bit more complicated than that as Volumio for PI supports at least all usb wifi dongles Raspbian OS does.
The Raspberry community has been supported by an older guy nicknamed “MrEngman” for a good number of years.
He added a number of wifi drivers and maintained them between Rasbian OS versions, which the offcial linux kernel did not.
Regrettably, about a year and a half ago, his support stopped for whatever reason.
Since then, these drivers are missing from the Raspberry OS linux kernel and, as Volumio uses the PI kernel, from the Volumio Pi images as well.
Hearing little snippets of information like this makes you realise the number of people there are behind the scenes keeping things going that we all owe our thanks too!
Instead of usb wifi, you could always use a wifi external receiver with lan output, then simple connect the raspberry pi using the rj45 port. I do that to configure my raspberry pi without wifi when first installing the OS.
Try something like AC1200 WiFi Range Extender (EX6120) from Netgear, it has one LAN port.
Hi I had the same issue so battled with a Realtek 5GHz dongle (88x2bu chipset based) to work really well. It took some getting going but has now been reliable with constant use over the christmas period even streaming HD Audio (352Khz @24 bit) from my NAS without issue. Testing my setup I get about 80Mbits peak which is not bad.
If you are interested, I wrote detailed instructions (raspberry pi 4b) here:
I’m also looking to add a subtle led that will indicate the bit depth and sample rate of now playing. I just need to learn how to code a plugin to connect to I2C
