Sorry for the Newbie question but where is the tgz file I need to restore my settings?
I do not understand ‘root of SMB share’ !!
I wanted to check it exists with WinSCP before trying a restore.
check:
/data/INTERNAL/volumio_data.tgz
Thanks. It’s empty, guess there is no backup available
I am trying to find if I have a changed Volumio setting as I can no longer get a lock from the PI / DIGI through UART to my Preamp Controller. Checking the settings before attacking the hardware.
it’s in the above folder i checked and just installed the plugin to try it again …
so if you don’t see a backup it’s not there you have to create it again…
you can scan with winscp for the file on your sd
Thanks for your help. I’ll try a scan, just in case!
PI4B, Volumio 3.816
Where does the update backup get stored and can a file be selectively restored from it?
I want to recover an old config.txt file that I had made some additions to.
