Hey, I want to use an external display over HDMI to see the now playing screen,
I’ve installed the touch display plugin and connected my 1080p screen over HDMI Port 0 but it’s just a black screen.
What do I have to configure to make it work?
@gvolt can you help him with this.
Some more information is required:
What is your Volumio version and are you on a fresh system?
What is the brand and model name of the screen?
I have the newest version of volumio and my screen is a LG 24BN550Y, but I plan on getting a smaller screen. This is just my second monitor for testing this
So, 3.198 I suppose.
Are you on a fresh Volumio installation?
Please connect to Volumio via SSH and post the output of
ls -al /usr/share/X11/xorg.conf.d
total 13
drwxr-xr-x 2 root root 1024 Feb 21 18:27 .
drwxr-xr-x 1 root root 1024 Feb 21 18:27 …
-rw-r–r-- 1 root root 92 Feb 7 2019 10-amdgpu.conf
-rw-r–r-- 1 root root 1350 Jan 4 10:05 10-quirks.conf
-rw-r–r-- 1 root root 92 Apr 6 2019 10-radeon.conf
-rw-r–r-- 1 root root 1429 Mar 31 2019 40-libinput.conf
-rw-r–r-- 1 root root 2747 Jun 26 2017 70-wacom.conf
Run
sudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-fbturbo.conf-HDMI -o /usr/share/X11/xorg.conf.d/99-fbturbo.conf
sudo sed 's/"fbturbo"/"fbdev"/' -i /usr/share/X11/xorg.conf.d/99-fbturbo.conf
and reboot.
Hi gvolt
I tried your code without “xorg.conf.d” since it is not in my directory.But my external monitor still not working…
https://ibb.co/0cCSdwc
any idea how to fix it?
I am able to see the file “99-fbturbo.conf” in /usr/share/X11/99-fbturbo.conf
Did you install and enable the Touch Display plugin?
What is the brand and exact model name of your display?
It is just an external/portable monitor without touch screen function.
No brand for this product, but It is mention that able to support PS4,XBOX,Switch, and most of the smart phone.
I tried it with my laptop, this external monitor working well…
I tried this >> https://community.volumio.com/t/plugin-touch-display/10647/2?u=neal_chin
the File is not Found >> ```
wget https://github.com/gvolt/volumio-touch_display-plugin/releases/download/v1.1.0/touch_display_1_1_1.zip
Don’t do that, it’s outdated.
I recommend to start from scratch with a fresh Volumio installation. Then install the Touch Display from the plugin store.
