Hi… as of right now, I am unable to connect to the laptop or mobile user interface on my Volumio streamer. The IP address I entered in both is the same. What could be the issue?wishing for everybody’s assistance
- Use a tool like advanced ip scanner to search you network for the device.
- Connect you mobile to the Volumio hotspot and see if you network is properly connected
try volumio.local on your browser address, instead of the IP address.
I get this sometimes on my wifi connected Volumio system (never on the wired one). I try the advice given above, but if I still can’t find it, the only cure is to pull the power and restart. Always a risk of corrupting the SD, so another reason to keep an up-to-date image backup. In my case, I point the finger at my ISP for providing a rubbish wifi router.
Yes… I tried to do both, but couldn’t connect.
I did the same technique… And it is connected now…![]()
Alright, I’ll try what you suggested if the issue arises again.![]()
Well you have a connection now. Seems your network isn’t stable if you keep loosing it.
Yes, occasionally the network drops, but up to now there have never been any issues.
