I have new USBridge and can’t use it. Volumio can’t recognize DAC connected to USBridge USB port.
Configuration: Volumio 2.513 + Sparky USBridge (J28 jumper NOT removed) + DAC Audio-GD NOS 19 + used delivered PSU (connected to Sparky)
DAC works on Sparky USB port - recognized Audio GD NOS19 as Combo384 Amanero and sounds good. DAC works correctly on RPI3 and Volumio.
DAC connected to USB USBridge (USB host) not recognized.
Already tested - not working:
- Tested with older Volumio versio for USbridge, the same problem.
- Factory reset, offered HDMI only as an option for output
- uenv.txt with aotg.aotg1_speed=1
- connect DAC after Volumio boot
- many other combinations and restarts
Connected to USBridge USB port
volumio@volumio2:~$ lsusb -t
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=aotg_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
Connected to Sparky USB port
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 3, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
volumio@volumio2:~$ aplay -l
card 0: atm7059link [atm7059_link], device 0: ATC2603C PCM atc2603c-dai-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: atm7059link [atm7059_link], device 1: HDMI PCM atm7059-hdmi-dai-1 []
Subdevices: 1/1
card 0: atm7059link [atm7059_link], device 2: SPDIF PCM atm7059-spdif-dai-2 []
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
card 1: Amanero [Combo384 Amanero], device 0: USB Audio [USB Audio]
Subdevices: 1/1
volumio@volumio2:~$ dmesg | grep high
[ 0.000000] Memory: 811148k/811148k available, 237428k reserved, 270336K highmem
[ 1.179110] mmc0: new high speed DDR MMC card at address 0001
[ 1.459980] ====otgvbus_gpio: num-78, active-high---detect_type=3,idpin_type=0,vbus_type=2---
[ 11.858385] usb 3-1: new high-speed USB device number 2 using aotg_hcd
[ 1.178445] mmc0: new high speed DDR MMC card at address 0001
[ 1.459475] ====otgvbus_gpio: num-78, active-high---detect_type=3,idpin_type=0,vbus_type=2---
[ 11.857805] usb 3-1: new high-speed USB device number 2 using aotg_hcd
[ 12.280223] usb 3-1.1: new high-speed USB device number 3 using aotg_hcd
volumio@volumio2:~$ dmesg | grep full
[ 1.141740] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
autoneg -> speed:100, duplex:full, pause: non-supported
[ 12.298461] usb 3-1.2: new full-speed USB device number 3 using aotg_hcd
[ 1.141103] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 12.478070] usb 3-1.2: new full-speed USB device number 4 using aotg_hcd
Any ideas what to test?
