I would like to increase my range over the RPI3 built-in WiFi. I have very little success connecting to it using the onboard card. I have a usb one that detects just fine, but I’m assuming I need to disable or configure away the onboard setup. The last few attempts at doing so have rendered the software unbootable…somehow?
In general, a USB dongle is small enough to fit into a pocket and someone can plug it into the USB port on a computer. Sometimes they include a wire that can be plugged into another device or computer, though many of them function as stand-alone hardware. The name “dongle” comes from uncertain origins, but likely originated in terms of security hardware, and has extended in use to other devices. If you want essay related topic you can go for custom essay writing service will get better result.
