Those are neat looking devices…
that I personally would not consider.
Oppo was the company to convince me of that. I jumped into the Sonica DAC in 2017 (I think it was…? Maybe ‘16, I forget).
Brilliant - similar all-in-one solution. The 2x bus-powered USB ports accepted at least 3-4TB drives each, and I got an 8TB Samsung SATA SSD to work, too (my music files are far in excess of 4TB).
There was a bit of glitch to the phone app after certain iOS updates; Oppo never really updated their software or firmware. Never mind - the occasional freeze / crash didn’t curb my enthusiasm.
Then their overseas parent company killed the CA lab about a year after my purchase. The Sonica app became high unstable then downright unusable (depending on the individual smart device being used). Connectivity for the unit was a real problem and eventually only possible via LAN attachment. Ultimately, I spent more time resetting the device and troubleshooting system freezes / crashes than I did listening to music.
It is still a great DAC, but even that’s not recognized by Volumio USB-in (I have not taken the time to reconnect the Oppo with the system to generate a log for inspection here, preferring to use “music time” for listening instead of troubleshooting that particular DAC). As an all-in-one, the Sonica has been truly obsolete since early/mid 2018. I can’t believe I stuck with it through half of last year until a friend asked me why I didn’t just use one of the RPi’s I had laying around, ha!
Anyway, those Eversolo units look promising. I’ve seen some similar Chinese versions in my neck of the woods, including one a couple years ago that offered 16TB of internal storage (!)
They seem to work great, but for me, they’re over-dependent on too many levels of company(ies) x hardware x software packages “playing nice together” through updates, so I lack faith in the possible ROI. A $2K unit better live a long time as a capable all-in-one to validate itself in this modern world of ~$100 great-testing DACs and inexpensive DIY streamers with abundant freeware. Stuff in the upstream zone is just evolving so quickly I prefer to keep with basic separates after getting a worst-case scenario of how AIO’s can go.
Mind you, mine is just an account of devil’s advocacy - I’m not trying to sway you. Those AIO units, for anyone willing to chance software interactions, hardware lifespan etc., that type of device can be a solid choice - especially if you use multiple streaming subscriptions more than your own file library (disclaimer: I only use my own files, no services streaming).
And yes, Vrms looks to be an easy solution in the case of both those Eversolo devices. Happy contemplating…!
