I’ve installed volumio and can connect fine, both ethernet and wlan working like a charm.
Only problem- I don’t have audio. Any ideas how to get my cheapo USB adapter (0d8c:000e C-Media Electronics, Inc. Audio Adapter (Planet UP-100, Genius G-Talk)) working? I can confirm it is supported on raspbian and found by lsusb.
I suppose also “aplay -L” shows that as audio interface. Anyway, at some point I was using Focusrite Scarlett 2i4 USB box (then with RaspyFI), supported and all. No sound out. Then I commented the whole audio_output section in mpd.conf as mpd is smart enough to look and find the default audio output in this case and it worked for me. Cheap to try at least.
Joe
