USB remote control?
Anybody here know if volumio will work with this?
hifiberry.com/shop/accessor … BgfbqhGwJc
I wish it did, but I don’t think so
I have a similar / look alike from a Kodi kit I bought a long time ago when I was in search for the perfect media player
At that time it workt nicely with a plugin , but today I think it’s native in Kodi
Hopefully is ther someone gifted with intrest that can make a plugin for Volumio
Too bad, is there another remote control system that could be used apart from this one? Because I was planning to implement a music component in a Raspberry Pi 4 based home automation system for one of these Torrevieja villas for sale, if everything goes right over the next 6 months, and it’d have been great if there was a way to control the music apart from using a computer/phone/tablet.
anyone know if this remote already works with volumio.
I have connect one. but does not seem to work out of the box.
I have instaled the remote plugin but does note make any differance.
hey, is there any USB remote that work with the Volumio player. that would sure hit the spot.
https://community.volumio.com/t/pifi-dac-with-ir-receiver-ir-remote-controller-plugin-justboom-ir-remote/38942
Using a JustBoom IR remote and a Dac with built in IR controller
I used a g40s remote which has a mini USB dongle RF receiver. I think It worked out of the box for the commands next, previous, pause/play and volume but I couldn’t get the power off to work initially.
I tried a number of methods to get power off to work but none would. So I ended up using this method under the heading ‘Headless or No Desktop Keybindings’ which worked.
I then edited the audio.conf file as follows
#VOLUMIO TRIGGERHAPPY CONFIGURATION FILE LOCATED AT /etc/triggerhappy/triggers.d/audio.conf
#MUTE TOGGLE
KEY_MIN_INTERESTING 1 /usr/local/bin/volumio volume toggle
#VOLUME UP
KEY_VOLUMEUP 1 /usr/local/bin/volumio volume plus
#VOLUME DOWN
KEY_VOLUMEDOWN 1 /usr/local/bin/volumio volume minus
#PLAY PAUSE TOGGLE
KEY_PLAYPAUSE 1 /usr/local/bin/volumio toggle
#NEXT
KEY_NEXTSONG 1 /usr/local/bin/volumio next
#PREVIOUS
KEY_PREVIOUSSONG 1 /usr/local/bin/volumio previous
#STOP Not working
#KEY_BACKSPACE 1 curl localhost:3000/api/v1/commands/?cmd=stop
#KEY_BACKSPACE 1 /usr/local/bin/volumio stop
#CLEAR QUEUE
#KEY_HOMEPAGE 1 curl localhost:3000/api/v1/commands/?cmd=clearQueue
KEY_HOMEPAGE 1 /usr/local/bin/volumio clear
#PLAYLISTS
KEY_1 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=AlphaBlondy’
KEY_2 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=Armin’
KEY_3 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=BruceSpringsteen’
KEY_4 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=ChemicalBrothers’
KEY_5 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=Classics’
KEY_6 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=CosmicGate’
KEY_7 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=FatboySlim’
KEY_8 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=Misc’
KEY_0 1 curl localhost:3000/api/v1/commands/?cmd=‘playplaylist&name=Queen’
I used https://volumio.github.io/docs/API/REST_API.html to get the commands right.
The playplaylist&name is just the playlist name created in volumio. The names can’t have spaces in them or it doesn’t work. I can now press a number on the remote and it plays the corresponding playlist. It deletes the previous songs in the queue before adding the playlist.
