Hi there, I am new to this forum, but I have got my Raspberry Pi and Volumio up and running today.
I have been able to get Volumio to see my Flac music file on my Synology NAS.
The raspberry Pi is plugged into my Rega DAC via USB.
Problem no sound, I have looked at the settings and the output selector does not give me the option for USB?
Is there any other settings I need to set to select USB or have I missed something?
Be grateful for some assistance.
Thanks John
You could start be checking that the underlying ALSA system has recognised your USB DAC . Connect to your RPi via ssh from another computer and use this command: aplay -l ( that’s a lower case letter L not the numeral one). You would expect to see something like this amongst the comand output:
card 1: default [USB Audio DAC ], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
Ok, thanks for the advice. I am going to do what you suggested at the weekend as I need some help with that.
Will post my findings when I have them.
Remember: connect the DAC before you turn Volumio on!
Let me know !
It lists play back hardware.
Card 0 DAC ( USB AUDIO DAC), device 0 USB Audio ( USB Audio)
Subdevices. 1/1
Card 1: ALSA (bcm2835 ALSA), device0: bcm2835 ALSA (bcm2835 ALSA)
Sub devices 8
Then lists subdevives 0-7
Plays through HDMI to monitor OK. Not that I want that?
Have DAC selected and mixer type software and it started working? Already tried all that once or twice so don’t know what I did different?
i am using Ipad and synology NAS just incase I didn’t mention it.
Playing Flac file sounds Good though
. Thanks.
