Hi, I have a raspberry pi 2 and want to try to usa a schiit modi 2 as a DAC. I have the pi connected to a 2A charger, would that suffice to power the modi with the pi? If not, someone knows good usb hub with an european plug for the modi and pi? Thanks.
The Modi 2 draws 130mA. It can be powered direct from a Pi model 3 (and 2 I believe) without needing a power supply/hub.
Your Pi needs a decent supply of course - 2A or so.
