I installed 2.713 yesterday and it’s not detecting my external USB HDD. I have tried several cables, different drives, different ports from the USBridge… No luck. Also clicking update & rescan several times, even resetting Volumio to factory settings. Nothing works.
Funnily it works with a 8GB pendrive with a handful of songs. But this 1TB 2,5" HDD has been working flawlessly since I started using Volumio.
Is anyone having the same issue? Maybe a bug from this version?
Can’t access music on my NAS either since installing 2.713 …
I have installed a new image of 2.713 and since then can’t access my music on my NAS (QNap) any more. Mounting the shares works and volumio starts to build a music database. It however breaks up after a while and from this time on there is no access possible to the NAS via menu item “Musikbibliothek”.
When mounting shares with only a limited number of tracks I can access the songs via “Interpreten”, access via “Musicbibliothek” is not possible.
Supposedly there is a fix, manually edit mpd.conf by setting those values
max_playlist_length “81920”
max_output_buffer_size “81920”
It has worked for some users, but not for me. I could see some of them were using a NAS, I am using a local USB hard disk, maybe that’s why it’s not working for me - but may work for you guys, give it a try.
