USB DAC reset between songs
Volumio 3.757 on Zotac Mini PC - Source NAS - playback USB connection to Cary Audio DMC 600SE - external DAC
Between songs the DAC clicks twice everytime, resetting the sampling rate, even though the sampling rate is constant across the album. This happens with all sampling rates - 192 or 44 or 98,6
Any comments, any help?
Does anybody know why this happens? Would love to get a response.
Seems this one only plays DSD and PCM.
Plops and Clicks on DSD playback are caused by switching sample rates or track changes. (Stream does not go to 0 on end of track, but stays active, DAC doesn’t handle this correctly, hence the clicks/plops)
You can try to change the playback setting from DSD Direct to DSD over PCM.
Hi, I changed it to DSD over PCM as suggested, sadly it still clicks. But thanks for the comment.
