usb dac doesn't recognized by Volumio
Hi.
I have installed Volumio on a raspberry some weeks ago.
A lot of times, wakeupping it didn’t play any sound.
I had to reset, to change temporary the Audio output, to return, to swap usb port, to try again… and in some way after 20 minutes of trials it was starting to sound.
So I have tried changing the dac.
Same story.
and now:
From this morning, it doesn’t see any dac in the “Audio Output”.
Tried with the two dacs and with two different cable, dozens of times, resetting, changing the usb ports.
The dacs doesn’t appear on the Audio Output.
Volumio works from the Audio jackl
The old dac: CambridgeAudio DacMagic 100
the new dac. Topping D30
Have you some ideas?
What can I try before to reinstall everyting or to try an alternative to Volumio?
thank you
this is a result of a sudo aplay -l
with both dac plugged in
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDM
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HD1]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi m5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 1/1
how can I ‘clean’ all the Usb drives?
Thank you
Can you help me only giving me some infos?
  • there is a way to clean the usb drivers?
  • is it a common problem? (I have try to search in the forum, but “usb” and “dac” are too common)
  • Have you already seen some discussions about similar subjects in the forum?
  • no alternetives to the reinstall?
Thank you
Stefano
