USB DAC compatibility List
Name: Topping D70 Pro Sabre
Receiver: XMOS XU316
DAC: ESS Sabre ES9039Pro
Async:
Working with Volumio: Yes
Tested Versions and Platforms: Volumio 3.703 RPi5B
Hardware Mixer on Volumio:
HW Mixer string:
Comments:
Buying Link:
Name: Topping D50 III
Receiver: N/A
DAC: Dual ES9039Q2M
Async: YES
Working with Volumio: YES
Tested Versions and Platforms: Raspberry Pi 5 with Volumio 3.742
Harware Mixer on Volumio: YES
Comments: It supports up to DSD 512 and PCM 768kHz, sounds amazing and, as a first in affordable DACs, it has parametric equalization.
Name: Rockna WaveLight
Receiver: Terminus Technology
DAC: R2R
Async: YES
Tested Versions and Platforms: Rivo
Harware Mixer on Volumio: NO
HW Mixer string:
Comments: No hickups, stable playback on Volumio Rivo
Buying Link: Wavelight PRE/DAC | Rockna Audio
Receiver: USB
DAC: Wolfson WM8740
Async:
Tested Versions and Platforms: Volumio-3.742-2024-07-22-x86_amd64
Harware Mixer on Volumio: No
Name: Aiyima A5 Pro
Receiver: USB Receiver (as well as toslink and coax, but I am using USB)
DAC: ES9018K2M
Async: Yes
Working with Volumio: Yes, perfectly
Tested Versions and Platforms: Version 3.757 Raspberry Pi
Harware Mixer on Volumio: Yes
HW Mixer string: N/A
Comments: No issues, works perfectly.
Buying Link: AIYIMA DAC A5 Pro | Headphone Amplifier | Digital Optical Coaxial PC U (can be bought from Aliexpress too)
Topping D70 Pro Octo is missing on this list.
Does anyone know whether it is supported?
I assume that no special drivers are required and that the D70 Pro Octo is supported generically, but this is just my assumption.
And while I’m at it, does anyone know if the D70 Pro Octo is audibly different from Allo’s Piano 2.1 (with Kali)? In this of course I am assuming that the rest of the chain is not a limitation.
This list was supposed to be dedicated to reporting supported DAC’s.
Anyhow, linux does not cater for supplier-specific drivers, the generic linux ā€œsnd-usb-audioā€ driver offers support for all recognized usb DAC’s, provided suppliers have had necessary device specific requirements (quirks) implemented in the usb audio ā€œquirksā€ tables. Some don’t care about linux, some quirks Volumio can help with.
Volumio offers some flexibility in case of DSD native capabilities. In some cases, depending on the hw platform (RPi, x86, volumio-own and some dedicated unsupported) specific quirks can be added.
Name: Fosi Audio ZD3
DAC: ESS Sabre ES9039Q2M
Async: Yes
Tested Versions and Platforms: Volumio 3.785 RPi 4B
Hardware Mixer on Volumio: NO on Preamp mode
HW Mixer string: -
Comments: No HW remote control, but includes remote control for preamp mode. Haven’t tested hardware mixer on bypass / pure DAC mode yet. Excellent bit of kit.
Buying Link: Fosi Audio ZD3 Fully Balanced Desktop DAC
Name: TAGA Harmony DA-400
Receiver: XMOS XU216-512-TQ128
DAC: DAC ESS SABRE ES9038Q2M,
Async: YES
Tested Versions and Platforms: Working on PI 4 and Win 11
Comments: USB supprts all PCM 32bit / 44.1kHz - 768kHz DSD do DSD512* MQA
Buying Link: Gdzie kupić - TAGA Harmony
Name: Audio Analogue AAdac
Receiver: Combo384 Amanero (?)
DAC: Sabre ES9038
Async: ?
Working with Volumio: NO
Tested Versions and Platforms: Rivo+ 3.816 FW: 0.2.7
HW Mixer string: ā€œPCMā€, ā€œPCM,1ā€, ā€œCombo384 Amanero Validityā€
Comments: Tried all the different kinds of HW mixers, with the AAdac set in pre-amplifier mode.
I’m wondering if anyone else has tried this DAC with Volumio. It would be nice if the hardware volume control would work. I’m technically cable. I could hook up a Raspberry Pi to try out things (with a few pointers).
Buying Link: https://www.audioanalogue.com/en/products/aadac
Name: Holo Spring 3 Level 3
Receiver: Titanis 2.0 FPGA circuit
DAC: Full discrete R2R
Async: YES
Tested Versions and Platforms: Raspberry Pi 4B & Raspberry Pi 3
HW Mixer string:
Comments: None
Buying Link:
Name: Fosi Audio ZH3
Receiver : XMOS XU316
DAC: AKM AK4493SEQ
Async: Yes
Tested Versions and Platforms: Volumio 4.072 RPi 4B
HW Mixer string: -
Comments: No HW remote control. Includes remote control for preamp mode. Haven’t tested hardware mixer on bypass / pure DAC mode yet. Excellent bit of kit with a great headphone amp (balanced & single ended). It includes an analog line in which I’m still testing that apparently just goes straight to the into Volume Control Chip (NJU 72315) and OPA1612 opamps.
Also, I had to flash the device’s firmware to the latest version (v. 1.15) to fix occasional silent milliseconds at the beginning of tracks. At the moment of this post, you will need Windows for this.
Buying Link: Fosi Audio ZH3 All-in-One Desktop HiFi DAC/Headphone Amp/Preamp
Receiver: USB
DAC: RME ADI-2 DAC FS with ESS ES9028Q2M (also used as pre-amp)
Async:
Tested Versions and Platforms: Volumio 3.886
DAC Info: ADI-2-DAC FS - RME Audio Interfaces | Format Converters | Preamps | Network Audio & MADI Solutions
Name: Denafrips Enyo 15TH
Receiver : USB
DAC: R2R
Async: Yes
Tested Versions and Platforms: Volumio 4.119 x86
HW Mixer string: -
Comments: No HW remote control. DSD Direct perfectly working. Immediately recognised by Volumio. Tested with .flac (44.1 to 192 KHz pcm) and .dsf (2.82 and 5.64 MHz / DSF 128)
Name: Smsl - D200
DAC: ROHM BD34352EKV
Async: YES
Working with Volumio: yes, versión 4.119
Tested Versions and Platforms: Raspberry Pi 5 4gb
Comments:
Buying Link: https://smsl-audio.ru/catalog/amp-dac/dac/d200-cap/
addendum: Now added a QUAD Artera preamp. Pure analogue device. Much better than using the RME digital volume control. More auditory spaciousness, bass more controlled.
Now waiting for my 4.x update on Rivo.
