If i recall correct, in the last 3 beta releases it seems that the remote commands from my Pro-ject Pre Box S2 Digital are no longer retrieve/processed in Volumio. Before I was able to use the Prev. Play/Pause and Next button on my remote to control Volumio. Just noticed it isn’t working anymore in the last 2 or 3 builds. The log doesn’t reveal any entry.
The DAC is turned off from line power on a daily base. (to avoid a display burn-in as that’s always on)
It can’t be a bad USB connection as that would have impacted the sound as it runs on the same data line.
The error is gone, tried even a cold start again, but can’t get the error back.
maybe the DAC had a holiday.
This is really mind bugging…
