Here is a shorter log after failure change output to headphone then change output to usb dac. Then after a minute player gui says config change, player restart. Then audio resumes.
info: CALLMETHOD: audio_interface alsa_controller saveAlsaOptions [object Object]
info: CoreCommandRouter::executeOnPlugin: alsa_controller , saveAlsaOptions
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
info: Output device has changed, restarting MPD
info: Output device has changed, restarting Shairport Sync
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/mpd.conf
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart mpd.service
Stopping Music Player Daemon...
info: Could not detect Primo: Error: Command failed: aplay -l | grep es90x8q2m-dac-dai-0
info: Found match in Cards Database: setting mixer Headphone for card Headphones
info: CoreCommandRouter::volumioUpdateVolumeSettings
info: Updating Volume Controller Parameters: Device: 1 Name: Headphones Mixer: Headphone Max Vol: 100 Vol Curve; logarithmic Vol Steps: 10
info: MPD Permissions set
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
info: CoreCommandRouter::executeOnPlugin: mpd , getPlaybackMode
info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
info: Starting Shairport Sync
info: VolumeController:: Volume=100 Mute =false
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart shairport-sync
Stopping Shairport Sync - AirPlay Audio Receiver...
Starting Shairport Sync - AirPlay Audio Receiver...
Started Shairport Sync - AirPlay Audio Receiver.
info: Shairport-Sync Started
info: CoreCommandRouter::volumioRetrieveVolumeLevels
info: CoreStateMachine::getcurrentVolume
info: CoreCommandRouter::volumioRetrievevolume
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: Device 5 does not have any Mixer Control Available, setting a softvol device
info: Updating Volume Controller Parameters: Device: 5 Name: Mixer: Max Vol: 100 Vol Curve; logarithmic Vol Steps: 10
mpd.service stop-sigterm timed out. Killing.
error: MPD error: Error: read ECONNRESET
mpd.service: main process exited, code=killed, status=9/KILL
Unit mpd.service entered failed state.
Starting Music Player Daemon...
