UPNP working correctly only when not logged to Volumio Premium
I have a problem with UPNP on Usb Audio Player Pro and Mconnect. Progress bar is not moving on phone, and next song is not being played after first is finished.
Problem occurs after logging to premium account. When not logged UPNP works like a charm.
@volumio can you reply? Problem still actual… what should I disable/do when logged to use UPNP without problems…
If you have Premium, create a support ticket to get support → Technical Support
