I’ve upgraded my Raspberry Model B from Volumio 1.5 to 2.0. I can ping volumio and login via SSH but I get ‘Unable to connect’ when I try to access the Web UI. I get the same result if I type the IP address into the browser.
The Cantata MPD client connects OK and returns server status.
I’ve checked /var/log/samba/log.smbd and there are no errors reported. However, I can’t identify the smbd daemon in the ‘ps’ listing and ‘service -status-all’ shows samba as stopped ‘[-]’. When I try to start samba it fails and I get a message saying the service is masked. ss -ta doesn’t show anything listening on port 80.
I’m not sure whether its related, but when I used sudo I got:
sudo: unable to mkdir /var/lib/sudo/lectured: No space left on device
sudo: unable to mkdir /var/lib/sudo/ts: No space left on drive
In case it is relevant I am using a HiFiBerry S/PDIF board.
I’ve a similar issue. The system is accessible via SSH, but there’s no web server. node is easting up 100% CPU. I’ve waited more than one hour, but node is still using 100% CPU.
too late. I’ve disconnected my PolyVection PlainDAC+. After a reboot, the Web UI was accessible. I’ve changed audio settings to I2C Hifiberry DAC Plus. After connecting the DAC again and rebooting, the Web UI was still working and I’m able to play music.
volumio@volumio:~$ sudo journalctl -f
-- Logs begin at Thu 1970-01-01 00:00:08 UTC. --
Jan 01 00:01:33 volumio systemd[1]: Stopping Volumio Backend Module...
Jan 01 00:01:33 volumio systemd[1]: Starting Volumio Backend Module...
Jan 01 00:01:33 volumio systemd[1]: Started Volumio Backend Module.
Jan 01 00:01:34 volumio volumio[806]: 512 MB or less RAM Detected, need to enabl e swap
Jan 01 00:01:34 volumio volumio[806]: Enabling Swap
Jan 01 00:01:34 volumio volumio[806]: swapon: /data/swapfile: swapon failed: Dev ice or resource busy
Jan 01 00:01:34 volumio systemd[1]: dynamicswap.service: main process exited, co de=exited, status=255/n/a
Jan 01 00:01:34 volumio systemd[1]: Unit dynamicswap.service entered failed stat e.
Jan 01 00:01:42 volumio sudo[819]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USE R=root ; COMMAND=/bin/journalctl -f
Jan 01 00:01:42 volumio sudo[819]: pam_unix(sudo:session): session opened for us er root by volumio(uid=0)
Jan 01 00:01:45 volumio volumio[807]: /volumio/node_modules/fs-extra/lib/mkdirs/ mkdirs-sync.js:47
Jan 01 00:01:45 volumio volumio[807]: throw err0
Jan 01 00:01:45 volumio volumio[807]: ^
Jan 01 00:01:45 volumio volumio[807]: Error: ENOSPC: no space left on device, mk dir '/data/albumart'
Jan 01 00:01:45 volumio volumio[807]: at Error (native)
Jan 01 00:01:45 volumio volumio[807]: at Object.fs.mkdirSync (fs.js:922:18)
Jan 01 00:01:45 volumio volumio[807]: at mkdirsSync (/volumio/node_modules/fs-ex tra/lib/mkdirs/mkdirs-sync.js:29:9)
Jan 01 00:01:45 volumio volumio[807]: at Object.mkdirsSync (/volumio/node_module s/fs-extra/lib/mkdirs/mkdirs-sync.js:35:16)
Jan 01 00:01:45 volumio volumio[807]: at Object.setFolder (/volumio/app/plugins/ miscellanea/albumart/albumart.js:29:8)
Jan 01 00:01:45 volumio volumio[807]: at Object.<anonymous> (/volumio/index.js:1 7:10)
Jan 01 00:01:45 volumio volumio[807]: at Module._compile (module.js:541:32)
Jan 01 00:01:45 volumio volumio[807]: at Object.Module._extensions..js (module.j s:550:10)
Jan 01 00:01:45 volumio volumio[807]: at Module.load (module.js:458:32)
Jan 01 00:01:45 volumio volumio[807]: at tryModuleLoad (module.js:417:12)
Jan 01 00:01:45 volumio systemd[1]: volumio.service: main process exited, code=e xited, status=1/FAILURE
Jan 01 00:01:45 volumio systemd[1]: Unit volumio.service entered failed state.
Jan 01 00:01:45 volumio systemd[1]: Starting dynamicswap.service...
Jan 01 00:01:45 volumio systemd[1]: Started dynamicswap.service.
Jan 01 00:01:45 volumio volumio[825]: 512 MB or less RAM Detected, need to enabl e swap
Jan 01 00:01:45 volumio volumio[825]: Enabling Swap
Jan 01 00:01:45 volumio volumio[825]: swapon: /data/swapfile: swapon failed: Dev ice or resource busy
Jan 01 00:01:45 volumio systemd[1]: dynamicswap.service: main process exited, co de=exited, status=255/n/a
Jan 01 00:01:45 volumio systemd[1]: Unit dynamicswap.service entered failed stat e.
Jan 01 00:01:45 volumio systemd[1]: volumio.service holdoff time over, schedulin g restart.
Jan 01 00:01:45 volumio systemd[1]: Stopping Volumio Backend Module...
Jan 01 00:01:45 volumio systemd[1]: Starting Volumio Backend Module...
Jan 01 00:01:45 volumio systemd[1]: Started Volumio Backend Module.
Jan 01 00:01:45 volumio volumio[832]: 512 MB or less RAM Detected, need to enabl e swap
Jan 01 00:01:45 volumio volumio[832]: Enabling Swap
Jan 01 00:01:45 volumio volumio[832]: swapon: /data/swapfile: swapon failed: Dev ice or resource busy
^Cvolumio@volumio:~$
and a few minutes after booting:
[code]volumio@volumio:~$ sudo journalctl -f
Jan 01 00:05:01 volumio systemd[1]: Stopping Volumio Backend Module...
Jan 01 00:05:01 volumio systemd[1]: Starting Volumio Backend Module...
Jan 01 00:05:01 volumio systemd[1]: Started Volumio Backend Module.
Jan 01 00:05:01 volumio volumio[1157]: 512 MB or less RAM Detected, need to enable swap
Jan 01 00:05:01 volumio volumio[1157]: Enabling Swap
Jan 01 00:05:01 volumio volumio[1157]: swapon: /data/swapfile: swapon failed: Device or resource busy
Jan 01 00:05:01 volumio systemd[1]: dynamicswap.service: main process exited, code=exited, status=255/n/a
Jan 01 00:05:01 volumio systemd[1]: Unit dynamicswap.service entered failed state.
Jan 01 00:05:08 volumio sudo[1170]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Jan 01 00:05:08 volumio sudo[1170]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Jan 01 00:05:12 volumio volumio[1158]: /volumio/node_modules/fs-extra/lib/mkdirs/mkdirs-sync.js:47
Jan 01 00:05:12 volumio volumio[1158]: throw err0
Jan 01 00:05:12 volumio volumio[1158]: ^
Jan 01 00:05:12 volumio volumio[1158]: Error: ENOSPC: no space left on device, mkdir '/data/albumart'
Jan 01 00:05:12 volumio volumio[1158]: at Error (native)
Jan 01 00:05:12 volumio volumio[1158]: at Object.fs.mkdirSync (fs.js:922:18)
Jan 01 00:05:12 volumio volumio[1158]: at mkdirsSync (/volumio/node_modules/fs-extra/lib/mkdirs/mkdirs-sync.js:29:9)
Jan 01 00:05:12 volumio volumio[1158]: at Object.mkdirsSync (/volumio/node_modules/fs-extra/lib/mkdirs/mkdirs-sync.js:35:16)
Jan 01 00:05:12 volumio volumio[1158]: at Object.setFolder (/volumio/app/plugins/miscellanea/albumart/albumart.js:29:8)
Jan 01 00:05:12 volumio volumio[1158]: at Object.<anonymous> (/volumio/index.js:17:10)
Jan 01 00:05:12 volumio volumio[1158]: at Module._compile (module.js:541:32)
Jan 01 00:05:12 volumio volumio[1158]: at Object.Module._extensions..js (module.js:550:10)
Jan 01 00:05:12 volumio volumio[1158]: at Module.load (module.js:458:32)
Jan 01 00:05:12 volumio volumio[1158]: at tryModuleLoad (module.js:417:12)
Jan 01 00:05:12 volumio systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Jan 01 00:05:12 volumio systemd[1]: Unit volumio.service entered failed state.
Jan 01 00:05:12 volumio systemd[1]: Starting dynamicswap.service...
Jan 01 00:05:12 volumio systemd[1]: Started dynamicswap.service.
Jan 01 00:05:12 volumio systemd[1]: volumio.service holdoff time over, scheduling restart.
Jan 01 00:05:12 volumio systemd[1]: Stopping Volumio Backend Module...
Jan 01 00:05:12 volumio systemd[1]: Starting Volumio Backend Module...
Jan 01 00:05:12 volumio systemd[1]: Started Volumio Backend Module.
Jan 01 00:05:12 volumio volumio[1176]: 512 MB or less RAM Detected, need to enable swap
Jan 01 00:05:12 volumio volumio[1176]: Enabling Swap
Jan 01 00:05:12 volumio volumio[1176]: swapon: /data/swapfile: swapon failed: Device or resource busy
Jan 01 00:05:13 volumio systemd[1]: dynamicswap.service: main process exited, code=exited, status=255/n/a
Jan 01 00:05:13 volumio systemd[1]: Unit dynamicswap.service entered failed state.
^Cvolumio@volumio:~$[/code]
