Nov 24 09:53:28 music volumio[1027]: info: Partition removed: {"syspath":"/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-2/2-2:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1","ACTION":"remove","DEVLINKS":"/dev/disk/by-partuuid/a59d1fae-01 /dev/disk/by-label/MUSIC /dev/disk/by-id/usb-KINGSTON_SA400S37480G_235678C218CA-0:0-part1 /dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:2:1.0-scsi-0:0:0:0-part1 /dev/disk/by-uuid/D7E1-F630","DEVNAME":"/dev/sda1","DEVPATH":"/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-2/2-2:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1","DEVTYPE":"partition","DISKSEQ":"26","ID_BUS":"usb","ID_FS_LABEL":"MUSIC","ID_FS_LABEL_ENC":"MUSIC","ID_FS_TYPE":"vfat","ID_FS_USAGE":"filesystem","ID_FS_UUID":"D7E1-F630","ID_FS_UUID_ENC":"D7E1-F630","ID_FS_VERSION":"FAT32","ID_INSTANCE":"0:0","ID_MODEL":"SA400S37480G","ID_MODEL_ENC":"\\x20SA400S37480G\\x20\\x20\\x20","ID_MODEL_ID":"a2a4","ID_PART_ENTRY_DISK":"8:0","ID_PART_ENTRY_NUMBER":"1","ID_PART_ENTRY_OFFSET":"2048","ID_PART_ENTRY_SCHEME":"dos","ID_PART_ENTRY_SIZE":"937699328","ID_PART_ENTRY_TYPE":"0xb","ID_PART_ENTRY_UUID":"a59d1fae-01","ID_PART_TABLE_TYPE":"dos","ID_PART_TABLE_UUID":"a59d1fae","ID_PATH":"platform-fd500000.pcie-pci-0000:01:00.0-usb-0:2:1.0-scsi-0:0:0:0","ID_PATH_TAG":"platform-fd500000_pcie-pci-0000_01_00_0-usb-0_2_1_0-scsi-0_0_0_0","ID_REVISION":"4101","ID_SERIAL":"KINGSTON_SA400S37480G_235678C218CA-0:0","ID_SERIAL_SHORT":"235678C218CA","ID_TYPE":"disk","ID_USB_DRIVER":"uas","ID_USB_INTERFACES":":080650:080662:","ID_USB_INTERFACE_NUM":"00","ID_VENDOR":"KINGSTON","ID_VENDOR_ENC":"KINGSTON","ID_VENDOR_ID":"7825","MAJOR":"8","MINOR":"1","PARTN":"1","SEQNUM":"2443","SUBSYSTEM":"block","TAGS":":systemd:","USEC_INITIALIZED":"3950369"}
Nov 24 09:53:28 music kernel: sd 0:0:0:0: Device offlined - not ready after error recovery
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=35s
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 31 38 40 00 00 02 00
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=35s
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 31 38 42 00 03 fe 00
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=35s
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 31 3c 40 00 00 02 00
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=35s
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 31 34 42 00 03 fe 00
Nov 24 09:53:28 music kernel: FAT-fs (sda1): FAT read failed (blocknr 2269)
Nov 24 09:53:28 music sudo[4062]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/umount -f /dev/sda1
Nov 24 09:53:28 music sudo[4062]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 24 09:53:28 music sudo[4062]: pam_unix(sudo:session): session closed for user root
Nov 24 09:53:28 music volumio[1027]: umount: /media/MUSIC: target is busy.
Nov 24 09:53:28 music volumio[1027]: error: Failed to umount MUSIC: Error: Command failed: /usr/bin/sudo /bin/umount -f "/dev/sda1"
Nov 24 09:53:28 music kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Nov 24 09:53:28 music kernel: FAT-fs (sda1): Directory bread(block 36640066) failed
Nov 24 09:53:28 music kernel: FAT-fs (sda1): Directory bread(block 36640067) failed
Nov 24 09:53:28 music kernel: FAT-fs (sda1): Directory bread(block 36640068) failed
Nov 24 09:53:28 music kernel: FAT-fs (sda1): Directory bread(block 36640069) failed
Nov 24 09:53:28 music kernel: FAT-fs (sda1): Directory bread(block 36640070) failed
Seems the drive was unplugged from the system and causing errors.
@DED , @nerd
Any suggestions on this?
