I’m using the latest generation of Raspberry-Pi with Volumio and a HifiBerry-Digi which drives a Marantz DAC.
The DAC is limited to 44kHz, so I’m using the interpolator modes to listen to higher sample rate files.
I’m experiencing unstable playback with the higher quality interpolator modes.
Can anyone suggest an alternative to the Raspberry-Pi that can deliver stable performance with the highest quality interpolator mode enabled on Volumio?
Best regards,
Alex
