today I tryed to update my volumio-raspberry pi installation with update V2.513 but after several attempts the update seems correctly downloaded and installed but after the System page always shows me the previous version 2.502
I powered off and on again without success.
Is any other procedure to perform the Volumio update ?
In any case Volumio is working fine.
Thanks in advance
Hmm, I noticed this earlier too, but the update had been applied just not reported correctly. If you can ssh into your device, run ‘cat /etc/os-release’ to get the actual version installed. Btw, at some point later (not sure when), the UI was reporting the correct v2.513. Perhaps, it is a cache thing??
For me without problems, the system shows that I have the latest version from December 7
