Since the update seem to be scanning continuously. Will complete then restart again this is on Pi3 i can provide logs if required.
This is a test version, which you’re not meant to install.
I suggest to revert back to the regular version by downloading it again.
Thanks for your feedback anyway
This came though as a standard update, I only have the dev for plugins. If I turn on dev for plugins does that also enroll me into the dev update Chanel?
You can enable to types for testing.
- Volumio
- Plugins.
So select for test Mode => False. Then it will only install stable releases
I am testing the very same version 3.543 and I cannot reproduce the problem
are you sure you don’t have any corrupted track in your library?
I have triggered a rescan to rebuild the database and will see how that goes. I will report back if it loops again.
