Update to v0.986 failed
Today I randomly checked for a system update. Update to v0.986 was available. The update ran successfully. After the reboot “local host refused to connect”. This is on a x86 PC. See screen shots
I think you’ve enabled “TEST MODE” and updated to a version you were not to meant to update (test updates are risky, since they’re nightly builds…
So your bet is to reflash Volumio
Hey… I made a backup prior; no biggy. But I didn’t enable TEST MODE. All I did was go to System and selected check for updates. I don’t see an option to check ‘TEST MODE’ in the GUI.
