currently using version 2.129, when i hit Check Update nothing happens
how to update mannually? using the x86 version
can i update on the command line?
You can upgrade your system from the command line, not sure about Volumio though, doesn’t appear to have a .deb package.
[spoiler]From the settings check Network and note the IP. From a UNIX shell running ssh use the following command:
ssh <ip_address> -l volumio
Default password is volumio.
Then run the following command to upgrade your whole system:
sudo apt update && sudo apt dist-upgrade && sudo apt autoremove
[/spoiler]
Assuming you’ve read or tried these steps volumio.github.io/docs/User_Man … dates.html do that whilst tailing the logs.
Login using the method posted above. Then run the command below and THEN hit the update check / upgrade button, and see what happens:-
sudo tail -f /var/log/volumio.log
Ctrl-C to cancel that command, and Ctrl-D to quit the SSH shell session.
this is the message i get
[code] - info: Sending updateCheck to server
any ideas?
