I have just tried to update Volumio from 2.444 to 2.502. The update seemed to go fine and the Pi restarted but it still shows that I am running version 2.444?
Anyone got any ideas?
Cheers
Cheers
Can you ping the device
yes I can ping it
I just performed the update through the gui, and when it restarted, I get white screen on all devices. I am able to ping, I am able to ssh, was able to do limited apt upgrade after that, but still the gui does not load on any device. login loads, splash screen loads, then blank grey/white screen.
2018-12-01T06:13:09.231Z - error: error
2018-12-01T06:13:09.513Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
at /volumio/app/plugins/music_service/upnp_browser/index.js:83:67
at /volumio/app/plugins/music_service/upnp_browser/index.js:626:21
at Parser. (/volumio/node_modules/xml2js/lib/parser.js:303:18)
at emitOne (events.js:116:13)
at Parser.emit (events.js:211:7)
at SAXParser.onclosetag (/volumio/node_modules/xml2js/lib/parser.js:261:26)
at emit (/volumio/node_modules/sax/lib/sax.js:624:35)
at emitNode (/volumio/node_modules/sax/lib/sax.js:629:5)
at closeTag (/volumio/node_modules/sax/lib/sax.js:889:7)
at SAXParser.write (/volumio/node_modules/sax/lib/sax.js:1436:13)
at Parser.exports.Parser.Parser.parseString (/volumio/node_modules/xml2js/lib/parser.js:322:31)
at Parser.parseString (/volumio/node_modules/xml2js/lib/parser.js:5:59)
at /volumio/app/plugins/music_service/upnp_browser/index.js:625:24
at Request.handleRequestResponse [as _callback] (/volumio/node_modules/unirest/index.js:463:26)
at Request.self.callback (/volumio/node_modules/unirest/node_modules/request/request.js:187:22)
at emitTwo (events.js:126:13)
This is not a fatal error.
Most likely you’ve made some other custom tinkering via ssh.
Are you able to paste a complete log?
I hadn’t ssh’d into the device in several months until it failed to load the GUI after the upgrade. I can provide the complete volumio log…
2018-12-01T06:18:53.518Z - info: -------------------------------------------
2018-12-01T06:18:53.523Z - info: ----- Volumio2 ----
2018-12-01T06:18:53.525Z - info: -------------------------------------------
2018-12-01T06:18:53.526Z - info: ----- System startup ----
2018-12-01T06:18:53.528Z - info: -------------------------------------------
2018-12-01T06:18:53.894Z - info: Plugin folders cleanup
2018-12-01T06:18:53.894Z - info: Scanning into folder /volumio/app/plugins/
2018-12-01T06:18:53.895Z - info: Scanning category audio_interface
2018-12-01T06:18:53.896Z - info: Scanning category miscellanea
2018-12-01T06:18:53.897Z - info: Scanning category music_service
2018-12-01T06:18:53.898Z - info: Scanning category plugins.json
2018-12-01T06:18:53.899Z - info: Scanning category system_controller
2018-12-01T06:18:53.900Z - info: Scanning category user_interface
2018-12-01T06:18:53.901Z - info: Scanning into folder /data/plugins/
2018-12-01T06:18:53.902Z - info: Scanning category miscellanea
2018-12-01T06:18:53.903Z - info: Plugin folders cleanup completed
2018-12-01T06:18:53.905Z - info: -------------------------------------------
2018-12-01T06:18:53.906Z - info: ----- Core plugins startup ----
2018-12-01T06:18:53.906Z - info: -------------------------------------------
2018-12-01T06:18:53.909Z - info: Loading plugins from folder /volumio/app/plugins/
2018-12-01T06:18:53.916Z - info: Adding plugin upnp to MyMusic Plugins
2018-12-01T06:18:53.921Z - info: Adding plugin airplay_emulation to MyMusic Plugins
2018-12-01T06:18:53.924Z - info: Adding plugin upnp_browser to MyMusic Plugins
2018-12-01T06:18:53.931Z - info: Loading plugins from folder /data/plugins/
2018-12-01T06:18:53.937Z - info: Loading plugin “system”…
2018-12-01T06:18:53.982Z - info: Loading plugin “appearance”…
2018-12-01T06:18:55.573Z - info: Loading plugin “network”…
2018-12-01T06:18:56.153Z - info: Loading plugin “services”…
2018-12-01T06:18:56.159Z - info: Loading plugin “alsa_controller”…
2018-12-01T06:18:56.332Z - info: Loading plugin “wizard”…
2018-12-01T06:18:56.349Z - info: Loading plugin “volumio_command_line_client”…
2018-12-01T06:18:56.364Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T06:18:56.366Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T06:18:56.368Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T06:18:56.408Z - info: Loading plugin “upnp”…
2018-12-01T06:18:56.421Z - info: [1543645136421] Starting Upmpd Daemon
2018-12-01T06:18:56.423Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-12-01T06:18:56.426Z - info: Loading plugin “my_music”…
2018-12-01T06:18:56.444Z - info: Loading plugin “mpd”…
2018-12-01T06:18:56.947Z - info: Loading plugin “upnp_browser”…
2018-12-01T06:18:58.551Z - info: Loading plugin “networkfs”…
2018-12-01T06:18:58.601Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-12-01T06:18:58.603Z - info: Loading plugin “alarm-clock”…
2018-12-01T06:18:58.894Z - info: Loading plugin “airplay_emulation”…
2018-12-01T06:18:58.924Z - info: Starting Shairport Sync
2018-12-01T06:18:58.926Z - info: Loading plugin “last_100”…
2018-12-01T06:18:58.933Z - info: Loading plugin “webradio”…
2018-12-01T06:18:58.954Z - info: Loading plugin “i2s_dacs”…
2018-12-01T06:18:58.978Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-12-01T06:18:58.981Z - info: Loading plugin “volumiodiscovery”…
2018-12-01T06:18:59.066Z - info: Applying required configuration parameters for plugin volumiodiscovery
2018-12-01T06:18:59.107Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-12-01T06:18:59.109Z - info: Loading plugin “albumart”…
2018-12-01T06:18:59.140Z - info: Plugin example_plugin is not enabled
2018-12-01T06:18:59.141Z - info: Loading plugin “updater_comm”…
2018-12-01T06:18:59.331Z - info: Plugin mpdemulation is not enabled
2018-12-01T06:18:59.332Z - info: Loading plugin “rest_api”…
2018-12-01T06:18:59.348Z - info: Loading plugin “websocket”…
2018-12-01T06:18:59.389Z - info: Loading plugin “touch_display”…
2018-12-01T06:18:59.414Z - info: ___________ START PLUGINS ___________
2018-12-01T06:18:59.424Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-12-01T06:18:59.427Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-12-01T06:18:59.428Z - info: [1543645139428] CoreMusicLibrary::Adding element Media Servers
2018-12-01T06:18:59.460Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-12-01T06:18:59.461Z - info: [1543645139460] CoreMusicLibrary::Adding element Last_100
2018-12-01T06:18:59.464Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-12-01T06:18:59.464Z - info: [1543645139464] CoreMusicLibrary::Adding element Webradio
2018-12-01T06:18:59.466Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2018-12-01T06:18:59.485Z - info: -------------------------------------------
2018-12-01T06:18:59.486Z - info: ----- MyVolumio plugins startup ----
2018-12-01T06:18:59.486Z - info: -------------------------------------------
2018-12-01T06:18:59.488Z - info: Loading plugins from folder /myvolumio/plugins
2018-12-01T06:18:59.496Z - info: Loading plugins from folder /data/myvolumio/plugins
2018-12-01T06:18:59.499Z - info: Loading plugin “my_volumio”…
2018-12-01T06:19:00.115Z - info: Loading plugin “streaming_services”…
2018-12-01T22:46:56.904Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-12-01T22:46:56.907Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-12-01T22:46:56.951Z - info: Streaming services startup
2018-12-01T22:46:56.978Z - info: Loading i18n strings for locale en
2018-12-01T22:46:57.050Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-12-01T22:46:57.055Z - info: CoreCommandRouter::initPlayerControls
2018-12-01T22:46:57.069Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.071Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
2018-12-01T22:46:57.206Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.207Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.208Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.209Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.210Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-12-01T22:46:57.223Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-12-01T22:46:57.228Z - info: BOOT COMPLETED
2018-12-01T22:46:57.230Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-12-01T22:47:02.530Z - info: CoreCommandRouter::Close All Modals sent
2018-12-01T22:47:02.531Z - info: CoreCommandRouter::Close All Modals sent
2018-12-01T22:47:02.627Z - info: MyVolumio not started
2018-12-01T22:47:02.628Z - info: CoreStateMachine::resetVolumioState
2018-12-01T22:47:02.629Z - info: CoreStateMachine::getcurrentVolume
2018-12-01T22:47:02.630Z - info: CoreCommandRouter::volumioRetrievevolume
2018-12-01T22:47:02.645Z - info: CoreStateMachine::updateTrackBlock
2018-12-01T22:47:02.646Z - info: CorePlayQueue::getTrackBlock
2018-12-01T22:47:02.849Z - info: Setting Device type: Raspberry PI
2018-12-01T22:47:02.855Z - info: Volumio Kiosk Started
2018-12-01T22:47:02.857Z - info: Kiosk Started
2018-12-01T22:47:02.860Z - info: Cannot mount NAS myFLAC at system boot, trial number 1 ,retrying in 5 seconds
2018-12-01T22:47:02.863Z - info: MPD running with PID574 ,establishing connection
2018-12-01T22:47:03.011Z - info: VolumeController:: Volume=79 Mute =false
2018-12-01T22:47:03.013Z - info: CoreStateMachine::pushState
2018-12-01T22:47:03.015Z - info: CoreStateMachine::getState
2018-12-01T22:47:03.016Z - info: CorePlayQueue::getTrack 0
2018-12-01T22:47:03.018Z - info: CoreCommandRouter::volumioPushState
2018-12-01T22:47:03.018Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-12-01T22:47:03.071Z - info:
---------------------------- Client requests Volume 80
2018-12-01T22:47:03.074Z - info: VolumeController::SetAlsaVolume80
2018-12-01T22:47:03.090Z - info: CoreStateMachine::pushState
2018-12-01T22:47:03.091Z - info: CoreStateMachine::getState
2018-12-01T22:47:03.092Z - info: CorePlayQueue::getTrack 0
2018-12-01T22:47:03.092Z - info: CoreCommandRouter::volumioPushState
2018-12-01T22:47:03.093Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-12-01T22:47:03.200Z - error: error
2018-12-01T22:47:03.251Z - info: Volumio called home
2018-12-01T22:47:03.268Z - info: Reloading queue from file
2018-12-01T22:47:03.284Z - info:
2018-12-01T22:47:03.290Z - info: message= [50@0] {} No such directory, stack=Error: [50@0] {} No such directory
at MpdClient.receive (/volumio/app/plugins/music_service/mpd/lib/mpd.js:63:14)
at Socket. (/volumio/app/plugins/music_service/mpd/lib/mpd.js:43:10)
at Socket.emit (events.js:211:7)
at addChunk (_stream_readable.js:263:12)
at readableAddChunk (_stream_readable.js:246:13)
at Socket.Readable.push (_stream_readable.js:208:10)
at Pipe.onread (net.js:607:20)
2018-12-01T22:47:03.367Z - info: Setting volume on startup at 80
2018-12-01T22:47:03.375Z - info: CoreStateMachine::setRepeat null single undefined
2018-12-01T22:47:03.376Z - info: CoreStateMachine::pushState
2018-12-01T22:47:03.376Z - info: CoreStateMachine::getState
2018-12-01T22:47:03.377Z - info: CorePlayQueue::getTrack 0
2018-12-01T22:47:03.378Z - info: CoreCommandRouter::volumioPushState
2018-12-01T22:47:03.378Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-12-01T22:47:03.382Z - info: CoreStateMachine::setRandom false
2018-12-01T22:47:03.382Z - info: CoreStateMachine::pushState
2018-12-01T22:47:03.383Z - info: CoreStateMachine::getState
2018-12-01T22:47:03.383Z - info: CorePlayQueue::getTrack 0
2018-12-01T22:47:03.384Z - info: CoreCommandRouter::volumioPushState
2018-12-01T22:47:03.384Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-12-01T22:47:03.440Z - info: mDNS: A device disapperared from network
2018-12-01T22:47:03.441Z - info: mDNS Browse raised the following error TypeError: Cannot read property ‘toLowerCase’ of undefined
2018-12-01T22:47:03.581Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , checkAudioDeviceAvailable
2018-12-01T22:47:03.612Z - info: CoreCommandRouter::executeOnPlugin: system , versionChangeDetect
2018-12-01T22:47:03.640Z - info: mDNS: Found device flacster
2018-12-01T22:47:04.357Z - info: Shairport-Sync Started
2018-12-01T22:47:04.362Z - info: Shairport-Sync Started
2018-12-01T22:47:04.564Z - info: Upmpdcli Daemon Started
2018-12-01T22:47:05.194Z - info: mDNS: Found device flacster
2018-12-01T22:47:05.452Z - info: CoreCommandRouter::volumioGetState
2018-12-01T22:47:05.453Z - info: CoreStateMachine::getState
2018-12-01T22:47:05.454Z - info: CorePlayQueue::getTrack 0
2018-12-01T22:47:19.191Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:19.230Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:19.303Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:20.189Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:20.236Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:20.287Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:25.879Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2018-12-01T22:47:25.881Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-12-01T22:47:45.886Z - error: error
2018-12-01T22:47:46.802Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:46.848Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:46.898Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:47.806Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:47.868Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:47:47.906Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:35.889Z - error: error
2018-12-01T22:48:39.173Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:39.228Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:39.271Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:40.179Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:40.226Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:48:40.276Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:25.881Z - error: error
2018-12-01T22:49:26.610Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:26.662Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:26.689Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:27.590Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:27.636Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:49:27.685Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:15.887Z - error: error
2018-12-01T22:50:18.164Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:18.215Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:18.262Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:19.187Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:19.237Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
2018-12-01T22:50:19.294Z - error: message=Cannot read property ‘0’ of undefined, stack=TypeError: Cannot read property ‘0’ of undefined
