Hey there,
it is not possible to update my Volumio Primo HiFi edition (System-Version: 3.233 Released: Thu 24 Feb 2022 07:32:58 PM CET). When i click “Check Updates” the “Checking for Updates” window opens but it does not happen. Resetting to factory settings doesn’t help either, any ideas?
Cheers,
Joe
There where a specific issue with V3.233 that affected the Primo and others using the Tinkerboard S so that the update failed.
I don’t know if you still should use the link in the linked thread or if you need to create a support ticket. Maybe @DED can advise?
thx
Hi!
the link in the thread is OK
Davide
VOLUMIO TECH SUPPORT
