update issue
Guys, ok. Please help us understand where the problem is.
I prepared a script that will list which files were edited.
Please do this:
cd /volumio
wget -O - http://repo.volumio.org/Volumio2/Test-tools/listdynchanges.sh | bash
  • Then please paste the output here. This will help us understand what goes wrong and fix this issue. Thanks for the cooperation
Here we go:
wget -O - repo.volumio.org/Volumio2/Test-t … changes.sh | bash
converted ‘http://repo.volumio.org/Volumio2/Test-tools/listdynchanges.sh’ (ANSI_X3.4-1968) → ‘http://repo.volumio.org/Volumio2/Test-tools/listdynchanges.sh’ (UTF-8)
–2018-09-19 18:48:37-- repo.volumio.org/Volumio2/Test-t … changes.sh
Resolving repo.volumio.org (repo.volumio.org)… 136.144.176.248
Connecting to repo.volumio.org (repo.volumio.org)|136.144.176.248|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 292 [application/octet-stream]
Saving to: ‘STDOUT’
  •               100%[=====================>]     292  --.-KB/s   in 0s
2018-09-19 18:48:37 (17.8 MB/s) - written to stdout [292/292]
Preparing folder structure
Listing modified files
/mnt/overlay/dyn/volumio/app/plugins/audio_interface/upnp/presentation.html
/mnt/overlay/dyn/volumio/app/plugins/audio_interface/upnp/upmpdcli.conf
Restoring folders
Thanks, very useful
Ok, checked and the issue which brought those files to be modified has already been solved.
So people starting from a reasonably recent volumio install won’t suffer from this .
In any case, you can solve it with this command:
volumio updater restore volumio
This way you won’t loose your install and we will clear the “edited” files.
If anyone else suffers from this issue, please repeat the procedure above so we have other insights about what the problem could be.
thanks
Thank you. That was super-helpful.
Michelangelo’s fix worked perfectly in my case
Sent from my iPhone using Tapatalk
Please report your edited files before executing this.
Thanks much.
Dave.
Yes, but guys please let us know which files were edited. This is important!
To do it:
cd /volumio
Aside from the files that I knew I’d edited, it reported
/mnt/overlay/dyn/volumio/app/plugins/system_controller/network/wireless.js /mnt/overlay/dyn/volumio/app/plugins/audio_interface/upnp/upmpdcli.conf.tmpl /mnt/overlay/dyn/volumio/app/plugins/audio_interface/upnp/presentation.html
which I hadn’t touched.
Here the update from 2.452 to 2.457 failed. Running listdynchanges.sh had the following result:
Preparing folder structure Listing modified files find: `/mnt/overlay/dyn/volumio': No such file or directory Restoring folders
After running
volumio@volumio:~$ volumio updater restorevolumio Deleting Overlay content of /volumio folder Mounting overlay partition Overlay partition mounted, deleting /volumio folder on overlay Cleaning environment Done, restarting system Restarting I updated again. But after the reboot the system version was still 2.452 and listdynchanges.sh showed the same result as before.
I once again ran volumio@volumio:~$ volumio updater restorevolumio and after the restart listdynchanges.sh: Result was the same as above. So here “volumio updater restorevolumio” did not solve the problem.
Please tell us which plugins you’ve installed.
I suspect there is one plugin that overwrites /etc/os-release
Thank you michelangelo for the fast response!
Plugins installed:
IR Remote Controller (version from github)
miniDLNA (https://github.com/volumio/volumio-plugins/pull/188)
RemotePi
Touch Display (version from github)
Backup & Restore Data
In case it should be of interest the attributes of /etc/os-release are
lrwxrwxrwx 1 root    root       21 Jan  7  2015 os-release -> ../usr/lib/os-release
and the attributes of /usr/lib/os-release are
-rwxrwxrwx 1 volumio volumio      677 Aug 27 15:28 os-release
The content of os-release is:
[code]PRETTY_NAME=“Raspbian GNU/Linux 8 (jessie)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“8”
VERSION=“8 (jessie)”
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/
SUPPORT_URL=“http://www.raspbian.org/RaspbianForums
BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs
VOLUMIO_BUILD_VERSION=“7124eaf0213deb060cebb17ef631669189a6650e”
VOLUMIO_FE_VERSION=“b52b5dfa93e3b26d6f23f09c91a5b90b0a43edf0”
VOLUMIO_BE_VERSION=“273d2050e44b6f5ae901d967e346577f7ad86f2c”
VOLUMIO_ARCH=“arm”
VOLUMIO_VARIANT=“volumio”
VOLUMIO_TEST=“FALSE”
VOLUMIO_BUILD_DATE=“Mon Aug 27 17:21:50 CEST 2018”
VOLUMIO_VERSION=“2.452”
VOLUMIO_HARDWARE=“pi”
VOLUMIO_HASH=“1802c403029d39af3072f40e987e7ba4”
[/code]
EDIT:
One more thing: The system has been set up with 2.452 initially and has not been updated in the past.
I now manually mounted /dev/mmcblk0p3:
/bin/mkdir /mnt/overlay /usr/bin/sudo /bin/mount /dev/mmcblk0p3 /mnt/overlay
Then did
ls -al /mnt/overlay total 44 drwxr-xr-x 6 root root 4096 Jan 1 1970 . drwxrwxrwx 1 root root 4096 Oct 2 20:19 .. drwxrwxrwx 13 root root 4096 Aug 31 20:19 dyn drwx------ 2 root root 16384 Aug 27 15:21 lost+found drwxrwxrwx 2 root root 4096 Jan 1 1970 union drwxrwxrwx 3 root root 4096 Jan 1 1970 work
and
ls -al /mnt/overlay/dyn total 100 drwxrwxrwx 13 root root 4096 Aug 31 20:19 . drwxr-xr-x 6 root root 4096 Jan 1 1970 .. drwxr-xr-x 11 volumio volumio 4096 Oct 2 19:31 data drwxr-xr-x 31 volumio volumio 4096 Sep 7 19:15 etc drwxr-xr-x 3 root root 4096 Aug 27 15:20 home drwxrwxr-x 4 root root 4096 Aug 31 20:26 lib drwxrwxrwx 3 root root 4096 Sep 30 16:15 media drwxrwxrwx 3 root root 4096 Oct 2 20:19 mnt drwxr-xr-x 2 root root 4096 Aug 31 21:13 opt drwx------ 5 root root 4096 Oct 2 20:14 root drwxrwxrwx 2 root root 4096 Jan 1 1970 static drwxr-xr-x 8 volumio volumio 4096 Jun 1 2017 usr drwxr-xr-x 6 root root 4096 Aug 27 15:13 var
Any idea what could be the reason that “volumio” is missing here (as listdynchanges.sh already reported)? Even if a file in the volumio folder would have been changed the folder itself should still exist I guess.
Please do ls -al /mnt/overlay/dyn/etc
and if you see the os-release file, please paste its output here
No os-release file:
ls -al /mnt/overlay/dyn/etc total 448 drwxr-xr-x 31 volumio volumio 4096 Sep 7 19:15 . drwxrwxrwx 13 root root 4096 Aug 31 20:19 .. -rw------- 1 root root 0 Aug 27 15:17 .pwd.lock drwxr-xr-x 7 root root 4096 Aug 31 20:30 X11 drwxr-xr-x 2 root root 4096 Aug 31 20:30 alternatives drwxr-xr-x 2 root root 4096 Aug 31 20:25 calendar drwxrwxr-x 4 volumio volumio 4096 Aug 31 20:30 chromium-browser drwxr-xr-x 2 root root 4096 Aug 31 20:25 cron.daily drwxr-xr-x 2 root root 4096 Aug 31 20:25 cron.weekly drwxr-xr-x 2 root root 4096 Sep 7 19:14 default -rw-r--r-- 1 root root 4479 Nov 11 2016 drirc -rw-r--r-- 1 root root 20 Oct 2 21:52 fake-hwclock.data drwxr-xr-x 5 root root 4096 Aug 31 20:30 gconf drwxr-xr-x 2 root root 4096 Aug 31 20:25 groff -rw-r--r-- 1 root root 876 Aug 31 21:45 group -rw------- 1 root root 860 Aug 31 20:26 group- -rw-r----- 1 root shadow 746 Aug 31 21:45 gshadow -rw------- 1 root root 733 Aug 31 20:26 gshadow- drwxr-xr-x 2 root root 4096 Aug 31 20:53 init drwxr-xr-x 2 root root 4096 Sep 7 19:14 init.d -rw-r--r-- 1 root root 45841 Aug 31 21:44 ld.so.cache drwxr-xr-x 2 root root 4096 Aug 31 21:44 lirc drwxr-xr-x 5 root root 4096 Aug 31 21:44 logcheck drwxr-xr-x 2 root root 4096 Sep 7 19:14 logrotate.d -r--r--r-- 1 root root 33 Aug 27 15:19 machine-id -rw-r--r-- 1 root root 2981 Aug 31 21:05 mailcap -rw-r--r-- 1 root root 5170 Jun 27 2017 manpath.config drwxr-xr-x 2 root root 4096 Aug 31 21:05 matchbox drwxr-xr-x 2 root root 4096 Aug 31 20:26 menu-methods -rw-r--r-- 1 volumio volumio 5737 Sep 28 19:13 minidlna.conf -rwxrwxrwx 1 root root 205 Aug 27 15:22 modules -rwxrwxrwx 1 mpd audio 2915 Aug 27 15:49 mpd.conf lrwxrwxrwx 1 root root 12 Aug 27 15:21 mtab -> /proc/mounts -rw-r--r-- 1 root root 1709 Aug 31 21:45 passwd -rw------- 1 root root 1691 Aug 31 21:45 passwd- drwxr-xr-x 2 root root 4096 Aug 31 21:24 plymouth drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc0.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc1.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc2.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc3.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc4.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc5.d drwxr-xr-x 2 root root 4096 Sep 7 19:14 rc6.d drwxr-xr-x 2 root root 4096 Aug 31 20:26 rcS.d -rw-r--r-- 1 root root 149 Oct 2 21:52 resolv.conf -rw-r----- 1 root shadow 1036 Aug 31 21:45 shadow -rw------- 1 root root 1036 Aug 31 21:45 shadow- -rwxrwxrwx 1 volumio volumio 436 Oct 2 21:53 shairport-sync.conf drwxr-xr-x 2 root root 4096 Aug 27 15:22 ssh -rw-r--r-- 1 root root 319 Aug 31 21:45 subgid -rw------- 1 root root 297 Aug 27 15:21 subgid- -rw-r--r-- 1 root root 319 Aug 31 21:45 subuid -rw------- 1 root root 297 Aug 27 15:21 subuid- drwxr-xr-x 3 root root 4096 May 7 2017 systemd drwxr-xr-x 2 root root 4096 Aug 27 15:21 wpa_supplicant drwxr-xr-x 3 root root 4096 Aug 31 20:25 xdg
Interesting.
Can you post the output of df -h ?
Can you do an update and just before it restarts send us logs via /dev page?
df -h Filesystem Size Used Avail Use% Mounted on /dev/mmcblk0p2 2.2G 815M 1.3G 39% /imgpart /dev/loop0 235M 235M 0 100% /static overlay 27G 710M 25G 3% / devtmpfs 477M 0 477M 0% /dev tmpfs 489M 61M 428M 13% /dev/shm tmpfs 489M 4.7M 484M 1% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 489M 0 489M 0% /sys/fs/cgroup tmpfs 489M 28K 489M 1% /tmp tmpfs 489M 0 489M 0% /var/spool/cups tmpfs 20M 48K 20M 1% /var/log tmpfs 489M 0 489M 0% /var/spool/cups/tmp /dev/mmcblk0p1 61M 37M 24M 61% /boot tmpfs 98M 0 98M 0% /run/user/1000 /dev/mmcblk0p3 27G 710M 25G 3% /mnt/overlay
Will try ASAP :slight_smile:
Tried to update. Now I get the message
[code]Update failed
System Software Integrity check failed, manually edited files were detected. System Software Update is not possible under those circumstances. Please execute a Factory Reset or Delete User Data, then retry.[/code]
which did not happen before.
Running volumio updater restorevolumio did not help to get rid of the message.
listdynchanges still gives:
