Update folder option gone in Volumio 2.x?
first of all, as this is my first post in this forum, thanks for a fantastic product and a great community!
A while back i updated from 1.5 to 2.x (running latest now) and soon discovered that the “update folder” option for NAS drives was gone, or am I missing something?
seems like the only option to update library is to do a rescan?
that works but takes a very long time on a 70 000+ tracks library like mine.
a typical scenario for me is that I add an album and then want to listen to it at once, but since I need to do a full rescan that could take like 30-45 minutes or something
anyone know why Folder update disappeared?
are there any other way to update just a folder?
cheers
/f
I just updated to volumio 2 and I am experiencing the same problem.
Is there nobody that can explain where the update-option has gone? Is it not possible to update one folder only?
I would appreciate an answer very much - and thanks in advance.
There is an update button in “My Music” page.
Yes - of course there is, and I have found it.
But as far as I can see you can only update the whole library and not just one folder only by using that button.
