I updated from version 2.201 to 2.224. No problems.
Now I wanted to updat to version 2.245, nothing happens. I try it a few times with no success.
What can I do?
I also succesfully updated to 2.224. Updating to 2.245 does not work. I’m using a RPi 3. I uploaded my logs, and I also checked them myself. This seems to be the problem:
Jul 29 10:31:19 volumio systemd[1]: Starting volumio-remote-updater.service...
Jul 29 10:31:19 volumio systemd[1]: Started volumio-remote-updater.service.
Jul 29 10:31:19 volumio volumio-remote-updater[749]: /usr/local/bin/volumio-remote-updater: error while loading shared libraries: libboost_thread.so.1.63.0: cannot open shared object file: No such file or directory
Jul 29 10:31:19 volumio systemd[1]: volumio-remote-updater.service: main process exited, code=exited, status=127/n/a
Jul 29 10:31:19 volumio systemd[1]: Unit volumio-remote-updater.service entered failed state.
Hhm. I have the same problem (Version 2.222 on RasPi3), the update button doesn’t work anymore.
Unfortunately I am not able to connect to Volumio via SSH / putty. I get an error “Network error. Connection refused.” Has anyone an idea how to fix this?
When trying to use ‘Check Updates’ via the UI on v2.224, I am getting no response, despite that v2.246 is now available. Any option other than to re-flash with the latest?
