Volumio Information
Volumio Version: 2.861
Hardware: RPi 4 2GB
DAC: Sabaj DA2
Hi guys!
Just joined Volumio community and started to use Volumio.
Now I’m facing problem with USB DAC output:
After loading Volumio there is no music output, just a silent noise.
If I re-plug (or have a series of replugging) USB DAC it helps and music output appears. But after restarting Volumio I have the initial situation.
Tried both USB 2.0 and USB 3.0 ports - no difference.
Diagnostics when no output
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 3/3
card 5: v12 [SABAJ DA2 v1.2], device 0: USB Audio [USB Audio]
Subdevices: 1/1
volumio@volumio:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default
sysdefault:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
sysdefault:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
sysdefault:CARD=v12
SABAJ DA2 v1.2, USB Audio
front:CARD=v12,DEV=0
Front speakers
surround21:CARD=v12,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=v12,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=v12,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=v12,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=v12,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=v12,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=v12,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=v12,DEV=0
dsnoop:CARD=v12,DEV=0
hw:CARD=v12,DEV=0
plughw:CARD=v12,DEV=0
volumio@volumio:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 152a:85df Thesycon Systemsoftware & Consulting GmbH
Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 002: ID 2109:3431
Diagnostics when normal, after re-plugging
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 0/1
null
pulse
default
hw:CARD=ALSA,DEV=0
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
sysdefault:CARD=v12
Front speakers
dmix:CARD=v12,DEV=0
hw:CARD=v12,DEV=0
Bus 001 Device 005: ID 152a:85df Thesycon Systemsoftware & Consulting GmbH
Thought that it might be some kind of problem with USB power. But DAC takes about 200mAh.
Tried to plug a USB HDD (about 350-400mAh) - no problem, works well.
Also tried different adapters (3A and 3.1A) - no changes.
With analog (3.5mm) output from RPi is OK.
The DAC itself works well when plugged into Win10 laptop, no output problems.
Maybe someone have any idea what can help or encountered something similar?
Thanks!
