Yes, and that won’t change for the reason you mentioned.
Switching to k6 will only occur when an alternative boot button method has been implemented.
@Wheaten i dropped the question at HK as they were calling for a C4 kernel 6.6.y debugging party.
No answer yet.
I am patient.
Volumio runs OK on the K4.9. Till now I’ve no need for a 6.x kernel (want it though to stay current and updated), but for Volumio the current is working.
Thanks for the builds @gkkpch,
i tried the 3.611 on C4@eMMC and lineout.
Have had two issues:
Spotify plugin can not be installed.
All versions 4.0.4 and down to 4.0.1 can’t be installed.
Spotify can not be uninstalled on plugin-manager. Install process on FusionDSP fails then as well. Reboot didn’t help.
After re-flash of eMMC it was possible to install FusionDSP as first step. Installation of Spotify fails same way.
Is there some workaround for that?
The volume level compared to “HiFiBerry DAC+ Zero(on Moode)” is only a half.
I searched for a specs of C4s Lineout. What is the vRMS of C4 lineout?
Is that a settings issue or hardware design issue with volume level?
Has somebody compared the quality C4 vs N2+ vs some HifyBerry(Master clocked)?
Thanks Gé for the M1S image.
Started to test today and it’s a marvelous piece of Hardware.
Volumio runs smooth and performs better then the rPi4, even thought it runs on a RK3566.
The internal sound, via SPDIF is more then acceptable.
New version 3.629 available, sorry that it took a bit longer to update here.
See Opening Post
Thanks Gé
image Volumio-3.629-2024-02-24-odroidm1s is working very well as I already had it running for while.
Also image Volumio-3.629-2024-02-24-odroidn2 seems to work fine.
Only one thing found with the N2 v3.629 vs the rPi version. I need to add the option vers=3.0 again to a CIFS mount in order to mount it. This was corrected with the rPi version.
Error during creating the mount
first row with vers=3.0
2nd without
Correct, but there is nothing I can do at the moment, Odroid images are still using an old 4.9 kernel, but this is on the radar.
For N2 there is an experimental image using kernel 6.1, but lacks the power on/off as you have noticed.
I have a fix, but it has not been integrated yet. Expect it with the bookworm version.
For the C4 this also exists, but was never published because of lacking odroid HiFi hat drivers.
This will be fixed as well, also expect this with the bookworm version.
Ok, it’s not a show stopper. Just mentioning it as part of the testing.
So far the rest seems all OK.
Was just to let you know what the kernel situation is.
Once we have 6.1 (or 6.6, not sure yet), support for C4 and N2 is secured over a long period.
Version 3.703 is available for OTA updaters, direct download links:
Volumio-3.703-2024-06-08-odroidn2
Volumio-3.703-2024-06-08-odroidc4
And now also for M1S:
Volumio-3.703-2024-06-12-odroidm1s
Yes looking good
Hi, I would recommend a sound card-module for the M1S for my handy son
(16 years old). Thank you. ![]()
Unfortunately, there is none for an M1S (same for N2).
Just get a USB DAC, they will work like a charm.
Or use SPDIF out from the extra header to an amplifier with spdif-in connector.
I tested it, it works fine.
Hardkernel has a nice module for connecting coax, ask @odroid.
@ gkkpch
Thank you for the information!
While anticipating the Volumio 4 Beta, the following problem arised.
Odroid N2/N2+ probably will (and with it the C4, as it is, buildwise, nearly the same) get support as one of the Odroid community portings I will maintain for the time being.
However, this cannot be said for the M1S, for which the download figures are extremely low (28 up to date).
Should there be volunteers for maintaining the current work, then please PM.
Otherwise I see no other way to discontinue the support for the m1s due to low interest.
I will consider the Odroid C5, which Hardkernel just released, at a later stage as it appears to be an extremely fast device, also because of price/performance. Getting it to run should not be an issue, but it is the same as with m1s, if there is not enough demand, it is not going to happen.
To make a long story short, how much interest is there for the M1S?
Please vote for the SBC you are currently using and would like to see updated. You may select up to two options.
- Odroid M1S
- Odroid C4
- Odroid C5
- Odroid N2/N2+
