Uninstall YouTube-Plugin not working
Hello
Thank you very much for the new version 2.555, I just updated my Volumio. Clear improvements - that’s great!
As a test, I have the plugin YouTube installed and can not uninstall it.
The uninstall seems to work normally, but the plugin is still installed after that.
Even a restart has brought no improvement.
It’s a small detail and it does not seem urgent.
regards
rost21A
I think that in version 2.555 uninstal not working on any plugin. But you can do it easy by deleting plugin folder in /data/plugins
the easiest way is to use WinSCP
Thanks for the tip!
From my Ubuntu desktop I’ve connected with SSH to Volumio and deleted the folder. (rm -r youtube)
Now the plugin is uninstalled :smiley:
Yes - i can confirm. Uninstalling plugins is not working with v2.555.
I testet on 4 different devices and many different plugins.
The only way is to delete the plugin folders from their /data/plugin/… locations
Plugins is what makes Volumio great against similar distributions. I hope the devs will spend a little more time into this again instead of only concentrating on the paid service things…
I prefer to donate - and also did so and will do in future.
Best Regards
Josef
I have been trying to use the volumio youtube plugin but I get this error every time I click on a song. I don’t have a problem with authorizing it just says something about not being able to decode the video. volumio error.PNG
Uninstall explicit filter profanity in Revanced youtube apk third parties. Need Uninstall youtube app
