Unify or streamline Album List from Multiple Sources (USB, SD card, etc.) into single option
As the title says, I wonder if there is a way to create a single Music Library list or icon that indexes multiple drives in a single list.
Currently, Volumio displays icons for all available sources: USB, Internal, NAS, etc. and navigating between them implies the user needs to access each individually to look for albums.
Is there an option available that would seamlessly integrate multiple sources in a single Library icon?
Thanks in advance for the help!
Bump. Can this be effectively done - one Music Library item to rule them all (from multiple sources)?
Thinking about this - is maybe making a massive playlist the only way around it?
@Darmur
I don’t think it’s possible, but you can search for a certain album and it will give you the results across all available sources, both local and from streaming services
Thanks for your reply and letting me know!
