Volumio Information
Volumio Version: 2.882
Hardware: RPi4
DAC: HiFiBerry DAC2 HD
Plugins:
- Spotify
- Spotify Connect
- Roon
- Radio Paradise
Had this problem last version so factory reset, reinstalled and here we are again. I’ve not touched a thing on the RPi except through the VolumIO interface but the upgrade process fails due the software integrity check
I enabled live logging and got the following output which looks a lot like a filesystem issue to me. The upgrade process should definitely be a little smarter about catching issues like this especially considering how fickle sdcards can be.
Having said fixing it is a bit of a pest unless you have a spare linux box, pi or boot from USB.
info: Update: [object Object]
info: CoreCommandRouter::executeOnPlugin: updater_comm , checkSystemIntegrity
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
SQUASHFS error: zlib decompression failed, data probably corrupt
SQUASHFS error: squashfs_read_data failed to read block 0x13e9769c
SQUASHFS error: Unable to read data cache entry [13e9769c]
SQUASHFS error: Unable to read page, block 13e9769c, size 1cbbb
SQUASHFS error: squashfs_read_data failed to read block 0x161e38b0
SQUASHFS error: Unable to read metadata cache entry [161e38b0]
SQUASHFS error: Unable to read directory block [161e38b0:b3a]
SQUASHFS error: Unable to read directory block [161e38b0:e63]
SQUASHFS error: Unable to read directory block [161e46ab:1b1]
info: CoreCommandRouter::Close All Modals sent
I’m going to pop it in my linux desktop and do a quick e2fsck and see what comes back. After I’ve finished listening
EDIT: Ran e2fsck and issue still occurs so I’m going to go with some data corruption on the sdcard which will require reinstalling. Can I download an img of 2.882 somewhere?
