unable to login to qobuz after installing 2.572
Help!
I can´t login to qobuz after successfully installing version 2.572
Before the update everything was running fine! Please help me…
best regards,
Harry
Hi Harry,
can you confirm that:
  • You are on Virtuoso or Superstar plan?
  • Is your device listed on your MyVolumio profile?
  • Do you see a play button near it?
Let me know
Hi Michelangelo,
yes I´m on virtuoso and my device is listed in the web interface and is enabled. By the way, I´ve switched from monthley to the yearly plan today.
best regards,
Harry
On which platform are you?
I´m on Raspberry PI
Can you send me an email to info @ volumio dot org? I will guide you to solving the issue.
deleting the user data did the trick!
Thanks very much for the help Michelangelo. That´s what I call great user support!!
