Volumio Version: 2.779
Hardware: Asus Tinker Board S
DAC: LKS MH-DA004
I have tried installing Volumio to the eMMC, being careful to use an 8GB SD card to ensure that it fits. I get the error message Install to Disk failed: undefined.
With the jumper settings from factory just plug the usb lead from the tinkerboard to your computer and install volumio to the tinkerboard as you would to a micro sd, unplug from computer and plug the tinkerboard usb to the power source and follow the same steps as for a micro sd
I can try that but I’m going to need to find a powered USB hub to power the Tinker Board, as it requires over 2A when booting up and I doubt my computer can supply that.
I’m still left wondering why the Volumio facility isn’t working, though.
Hi dangermouse, I did as you suggest, flashing with etcher from a Mac. The procedure went fine, but Volumio does not boot. The yellow led of the TBS blinks and that’s it: no hotspot to connect to.
if I use the SD card, everything is fine.
I am using Volumio version released on June 8th
There is another way to flash to eMMC using UMS mode.
Prepare an SD card with Volumio
Put the Tinker S in maskrom mode
Remove any devices, incl. ethernet
Take a USB cable and power the Tinker S from your PC (windows or linux)
Tinker S now starts in UMS mode and will be connected to your PC as a USB storage device
This must be a board issue then. During testing I always flash with ums mode. Which will fail everytime I don’t pull all other devices off.
Just wonder whether the serial console would give any hint.
Sorry not to be of further help.
