Trying to run an apt-get update but archive.volumio.org times out. Any workaround?
Hi El_Doughnut, welcome to Volumio.
It works fine here, perhaps a temporary problem. Try again.
P.S. Please make sure that you DON’T run ‘sudo apt upgrade’ after your update, otherwise you risk ‘borking’ your system.
Same here, update is working.
Thanks. It’s working today. Couldn’t get to it all yesterday for some reason. Oh well, whatever.
