I have bought myself an uDOO quad recently and am having trouble setting up volumio. My only previous setups on the uDOO were arch based ones. Being such I am used to the arch setup process. Does anyone have any helpful pointers to setting up an uDOO quad with Volumio? Everytime I try I receive the following:
U-Boot 2015.01 (Jan 24 2015 - 18:35:39) Arch Linux ARM
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: Udoo
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: using phy at 6
FEC [PRIME]
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /boot/uEnv.txt ...
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
Thank you all for your support and help!
