Udoo Quad - eSata - no network shared disk
Since I started using eSata database with my Udoo, I can’t access network shared music files.
It’s actually invisible (I can see old mount though, called “USB Music”)
cheers,
Adam
bump
If you try to delete the lan storage and remount?
Inviato dal mio SM-N9005 utilizzando Tapatalk
I have new OS and still same issue.
There is “permanent” folder called “USB Music” (It was linked to usb HDD).
I’m using eSATA and I called my mount “eSata”, it’s not visible as shared catalog.
best,
Adam
help, help!
It is not clear, is the esata disk directly connected to udoo by an adaptor or what?
esata is directly connected to UDOO.
my HDD was working perfectly over the network via USB.
There is a workaround for esata disk and udoo, in other tread…I don’t have the link now.
The workaround was posted by michelangelo.
Ciao
